| diyAudio Sponsor | ||
I have a hundred of these little orphans but i canīt find any info about them. A double triode with a common cathode perhaps? I'll appreciate if someone has any data. |
#2 |
Possibly a 6J6.
Regards, KM
... just because you're paranoid, it doesn't mean they're not after you... |
#3 |
Could be a 6J6? Any chance of measuring heater current at 6.3V as the 6J6 has a quoted consumption of 450mA as opposed to the usual 300mA. It may help in your investigations.
Also see if you can identify the connections inside the glass envelope. For a 6J6, Pin 1 = A', Pin 2 = A'', Pin 3 = heater, Pin 4 = heater, Pin 5 = G'', Pin 6 = G', Pin 7 = Common Cathode. Les You just pipped me KM |
#4 |
If it LOOKS like a 12AU7 or 12AT7 inside, it might be a 2033. Heater current is 300 mA. Same pinout as 6J6.
#5 |
Many thanks for the help. I will check the internal connections.
I have edited the pic, now you can see better the ecc81 label. |
#6 |
I would suspect it's an ECC91 with smudgy print.
http://tdsl.duncanamps.com/show.php?des=ECC91 Regards, KM
#7 |
Excellent tube for push pull applications,
the link shows a homemade FM frontend: http://ukw-projekt.blogspot.com/2008...gegentakt.html Kind regards, Darius |
#8 | ||
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#9 |
Doesn't look quite like a normal 6J6, but that's probably because it's Russian.
6N15P. Does this look familiar? 6J6 is an alright tube, but she loves to oscillate here is data: http://www.klausmobile.narod.ru/td/data/_6n15p.GIF |
#10 |
OK, I didn't have time until this weekend but i have checked the tube and, yes : pinout same as 6J6.
And Colt is right; seems the Russian version. Thank you guys. |
| Ecc81 12at7 | 316a | Swap Meet | 0 | 30th May 2008 11:51 AM |
| Test of ECC81 to 83 | Hojvaelde | Tubes / Valves | 1 | 11th January 2008 01:02 PM |
| ECC81 | Tobruk | Tubes / Valves | 6 | 25th April 2007 02:47 PM |
| ecc81 | gianis | Swap Meet | 0 | 12th June 2006 08:44 PM |
| ECC81 or 83 or 85 or 88 ??? | Bernhard | Tubes / Valves | 1 | 26th December 2003 03:57 PM |
| Page generated in 0.10463 seconds (71.76% PHP - 28.24% MySQL) with 11 queries |
