diyAudio Sponsor
Old 9th February 2009, 05:46 AM   #1
Thumbs up My New pre-amplifier£¡
My pre-amplifier is composed of WE20A power supply and Pre-Amp Unit. Power supply WE20A reference Western Electric circuit. Pre-Amp Unit is an input transformer, after amplification in WE102F-WE101F for output transformer structure.Input Impedance is 600R,Output Impedance is 600R.Input Sensitivity is 120mv for 1V output.Output Noise at 0.35mv RMS,Frequency is 8-70000HZ -3DB.
Old 9th February 2009, 05:48 AM   #2
WE20A power supply:) :) :)
Old 9th February 2009, 06:13 AM   #3
analog_sa's Avatar
Default Re: My New pre-amplifier£¡
Any advantage to this peculiar choice?
Old 9th February 2009, 06:16 AM   #4
Default Re: Re: My New pre-amplifier£¡
Y
Old 9th February 2009, 07:04 AM   #5
analog_sa's Avatar
Then i assume all your sources have been suitably modified
Old 9th February 2009, 07:10 AM   #6
Miles Prower's Avatar
WE20A power supply
It's not gonna work since your series pass tube has a cold heater.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 9th February 2009, 07:41 AM   #7
Geek's Avatar
What does the WE412A || 5M do exactly?
Cheers!
Old 9th February 2009, 08:10 AM   #8
Pre-Amp Unit
Old 10th February 2009, 06:41 AM   #9
Old 10th February 2009, 07:58 AM   #10
Geek's Avatar
Did you see our questions?
Cheers!
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Page generated in 0.08931 seconds (80.61% PHP - 19.39% MySQL) with 11 queries
