Will this work as a differential stage?
Old 8th February 2009, 09:37 PM   #1
martyh is offline martyh  United States
Default Will this work as a differential stage?
Probably a silly question but would this work to get a low impedance differential drive?
Thanks,
Marty
Old 8th February 2009, 09:48 PM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Not terribly well, I think. The cathode followers are fine but the CCS isn't. Think about what would happen if the signal currents in the two valves were not equal - a very large signal voltage would develop across the CCS. What you'd really like is a current mirror in the cathodes.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 9th February 2009, 12:01 AM   #3
Thanks, I guess it was a silly question. A search on the forum for “current mirror” turned up plenty of threads where the idea I just drew was discussed at length.
Old 9th February 2009, 08:13 AM   #4
EC8010's Avatar
You're welcome.
Old 9th February 2009, 08:54 AM   #5
ErikdeBest is offline ErikdeBest  Switzerland
mostly thinkerer
Hi Martyh
The circuit you are proposing is a differential cathode follower !? I had not heard of it until recently, when it was extensively discussed in this thread
Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Will this work as a differential stage?Hide this!Advertise here!
JLH with a differential input stage mohan72 Solid State 46 10th September 2008 08:59 PM
Differential stage with CCS in cathode zigzagflux Tubes / Valves 6 31st March 2008 09:15 PM
Differential I/V stage? And RX input guzzler Digital Source 29 19th December 2006 06:32 PM
Differential input stage Dynsdale Tubes / Valves 8 3rd September 2005 08:29 PM
differential input stage xuesong Solid State 3 27th December 2004 03:08 PM
