| diyAudio Sponsor | ||
Having a hard time finding matching VU, mA (for bias), VDC (for B+) meters for the next project(s) - 56 linestage, JE Labs phono, separate P/S's and a pair of 6B4G PP monos with a separate PS...have 90% of the parts lined up but i can't start cutting until i know what meters i'm going to use...
Retro/art deco style would be cool, but i'm open. Need to be hi quality and no plastic! Many thanks |
#2 |
No plastic? Then these $7.95 panel meters are out... http://www.mpja.com/prodinfo.asp?number=17252+ME
Fair Radio has a few: http://www.fairradio.com/catalog.php...ategoryid=3985 |
#3 |
Here is a link to a thread containing information which may help.
I posted a couple of photo's of panel meters that I obtained and then modified from fairradio. They are high quality units. Where to Buy Panel Meters? |
#4 |
As a post script, the photo's are low resolution. The markings on the face are clean and precise, not slightly blurred as seen in the photo....
#5 |
Thanks guys!
Found another interesting site, http://www.electro-meters.com/Gossen...ffn_series.htm the Gossen, Triplett, and Yokogawa look pretty cool - the round mil-specs and Edgewise in particular. Perhaps they will do custom Vu as well, i'll ask. I'm guessing around $100/ea x 9 meters, not cheap but less than i thought.... |
#6 |
Weber just started selling a kit with two
retro meters to monitor the bias and b+. Inexpensive and looks pretty cool. https://taweber.powweb.com/store/mod...m#analog_meter |
#7 |
Assuming you had the money to blow, what meters (grid, dc, vu, etc) would you guys include in your preamps/PSs/amps/RIAAs - if any?
Is there a danger of introducing unwanted effects from monitoring these various readings? |
#8 | |
I haven't had any problems with this, though did include an on-off-on toggle switch that could disconnect the meter completely in case it did have some adverse effect. I just leave it on. |
| panel meters | CarlyBoy | Tubes / Valves | 32 | 31st August 2009 08:32 AM |
| Where to Buy Panel Meters? | d1983 | Parts | 22 | 20th February 2009 04:31 AM |
| Wanted: Funky old panel meters. | Spasticteapot | Swap Meet | 2 | 14th November 2006 11:14 AM |
| analog panel meters | merlinx76 | Parts | 0 | 26th January 2005 08:46 PM |
| Page generated in 0.09617 seconds (72.75% PHP - 27.25% MySQL) with 10 queries |
