my saturation test ??
Old 8th February 2009, 03:47 PM   #1
jeapel is offline jeapel  Canada
Default my saturation test ??
I would like to get your opinion on my saturation test.
My idea is the secondary inductance should drop
with DC on primary near to saturation but the result
is almost constant from 0 to 100ma.
My conclusion is my test is wrong or small cheap
transfo are not so easy to saturate.
Old 8th February 2009, 06:35 PM   #2
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Default Re: my saturation test ??
Saturation is a function of the volts per turns ratio and signal frequency. Best way is to crank up the primary voltage with a Variac while monitoring the current. The current will increase abruptly when the core saturates. It will also hum noticeably when that happens.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 8th February 2009, 07:54 PM   #3
thanks Miles
my saturation test ??Hide this!Advertise here!
Inductor saturation and capacitor differences Dave Bullet Multi-Way 8 18th March 2008 09:29 PM
Transformer saturation & leakage Lucius Planars & Exotics 8 8th April 2007 09:14 PM
Toroidal core saturation Klimon Tubes / Valves 3 11th July 2006 02:59 PM
Quasi-Saturation rarya Chip Amps 0 27th November 2003 07:17 AM
Copyright ©1999-2017 diyAudio
