| diyAudio Sponsor | ||
Well not really!
But what is this thing that looks like a DO-35 diode inside the glass envelope of a vacuum tube: http://www.r-type.org/pics/aaa0772b.jpg (Like to page: http://www.r-type.org/exhib/aaa0772.htm ) |
#2 |
Looks like a fuse. |
#3 |
The 'fuse' is not accessible. If it blows you'll have to throw out the tube.
Is there some seriously catastrophic scenario that needs such extreme protection ? (I'm a tube noob) (if it is a fuse, its protecting the gate) |
#4 | |
#5 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Its' a small signal RF diode............the kind we all used making our first AM radios!!
__________________________________________Rick.... .... |
#6 |
Looking at the close up view in the last picture on the page here
http://www.r-type.org/exhib/aaa0772.htm it appears to me to be some sort of mechanical support or stiffener. The lead going through it does not seem to actually go anywhere, it seems to be curved like a spring and is pressing against the bottom structure. Perhaps it reduced microphonics ?? If it was electrically connected somehow that I cant see then perhaps it is some sort of spark gap protection ??
Robert McLean |
#7 |
It isn't a support.
Its the only connection to the grid (gate). |
#8 | |
It appears to me that it goes to pin 5 which is open, and the thin line through it appears to be nothing more than a distorted image of a lead behind it. To me it appears to be nothing more than a support. (I'm using a very good CRT monitor and image magnification and that is what it looks like to me.) Tubes have grids, fets of various descriptions have gates.
www.kta-hifi.net |
#9 | |
Now its beginning to make sense to me - perhaps the purpose is to provide mechanical support without the inductance of a lead (at VHF) ? Is such a mechanism employed in any other tube ? |
#10 | |
external pin 5 . kevinkr is correct !! Regards , Carlos |
| diode bridge - 10000uF cap - diode tube - small cap - HV+ | engels | Tubes / Valves | 5 | 29th January 2008 10:16 PM |
| hybrid power supply: diode bridge into diode tube | engels | Tubes / Valves | 8 | 24th September 2007 09:18 AM |
| DIY Vacuum tube amp | turbo_h4 | Tubes / Valves | 2 | 1st July 2004 01:48 AM |
| Vacuum tude diode help | Philo | Tubes / Valves | 2 | 6th November 2003 06:36 PM |
| Page generated in 0.11248 seconds (72.48% PHP - 27.52% MySQL) with 10 queries |
