DO-35 diode inside vacuum tube ?
Old 8th February 2009, 03:37 AM   #1
pjp is offline pjp  India
pjp's Avatar
Default DO-35 diode inside vacuum tube ?
Well not really!
But what is this thing that looks like a DO-35 diode inside the glass
envelope of a vacuum tube: http://www.r-type.org/pics/aaa0772b.jpg
(Like to page: http://www.r-type.org/exhib/aaa0772.htm )
Old 8th February 2009, 04:01 AM   #2
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Looks like a fuse.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 8th February 2009, 04:18 AM   #3
pjp's Avatar
The 'fuse' is not accessible. If it blows you'll have to throw out the tube.
Is there some seriously catastrophic scenario that needs such extreme protection ?
(I'm a tube noob)
(if it is a fuse, its protecting the gate)
Old 8th February 2009, 04:18 AM   #4
astouffer is offline astouffer  United States
astouffer's Avatar
Looks like a fuse
How is the fuse changed when it decides to blow
Old 8th February 2009, 04:23 AM   #5
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Its' a small signal RF diode............the kind we all used making our first AM radios!!
__________________________________________Rick.... ....
Old 8th February 2009, 02:55 PM   #6
Robert McLean is offline Robert McLean  Canada
Looking at the close up view in the last picture on the page here
it appears to me to be some sort of mechanical support or stiffener. The lead going through it does not seem to actually go anywhere, it seems to be curved like a spring and is pressing against the bottom structure. Perhaps it reduced microphonics ??
If it was electrically connected somehow that I cant see then perhaps it is some sort of spark gap protection ??
Robert McLean
Old 8th February 2009, 07:47 PM   #7
pjp's Avatar
It isn't a support.
Its the only connection to the grid (gate).
Old 8th February 2009, 08:55 PM   #8
kevinkr's Avatar
Originally posted by pjp
It isn't a support.
It appears to me that it goes to pin 5 which is open, and the thin line through it appears to be nothing more than a distorted image of a lead behind it. To me it appears to be nothing more than a support. (I'm using a very good CRT monitor and image magnification and that is what it looks like to me.)
Tubes have grids, fets of various descriptions have gates.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 9th February 2009, 01:20 AM   #9
pjp's Avatar
Now its beginning to make sense to me - perhaps the purpose is to provide mechanical support without the inductance of a lead (at VHF) ?
Is such a mechanism employed in any other tube ?
Old 9th February 2009, 02:33 AM   #10
refference is offline refference  Brazil
................ mechanical support without the inductance of a lead (at VHF) ?
I don't think so . The purpose is to provide INSULATION , between the internal electrode where it is connected and the
external pin 5 .
kevinkr is correct !!
Regards ,
Carlos
DO-35 diode inside vacuum tube ?Hide this!Advertise here!
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 01:48 AM
Vacuum tude diode help Philo Tubes / Valves 2 6th November 2003 06:36 PM
