| diyAudio Sponsor | ||
Hello,
In regards to the following output transformer, I have a few questions: http://www.tubesandmore.com/cemirror...50c_wiring.gif Single Ended environment: On the secondary side, which gets connected to speaker positive and which gets connected to speaker negative? I thought black was negative, but looking at the diagram, there is a dot and black is labeled (Com). On the primary side, which gets connected to the plate and which gets connected to power supply? I have blue connected to plate and red connected to power supply. I bet I mixed something up because when I connect the negative feedback loop to speaker jack positive (as schematic shows), I get oscillation. Please let me know if I messed up the polarity of the transformer wiring. Thanks!!! |
#2 | ||
#3 |
Thanks Miles.
There is only one secondary tap – 4ohms (well, technically 3.2). I wonder if I could accomplish the same thing by switching the secondary side orientation. I only ask because it is easier access. Thanks again!!! |
#4 | |
#6 |
diyAudio Moderator Emeritus
There can be no convention for the primary. As Miles says, the transformer maker can't know whether there is an odd or even number of gain stages in the NFB loop.
| Help with phase/polarity of transformer | jakebrown5 | Power Supplies | 21 | 27th August 2007 01:38 AM |
| Dual transformer polarity/wiring | Zero Cool | Everything Else | 15 | 20th March 2007 03:19 PM |
| Does (primary) transformer AC polarity matter...? | ptwining | Class D | 14 | 28th October 2006 12:19 PM |
| LED polarity | guitargully | Solid State | 4 | 12th January 2004 04:14 AM |
| Page generated in 0.08987 seconds (72.89% PHP - 27.11% MySQL) with 10 queries |
