diyAudio Sponsor
Old 7th February 2009, 07:02 PM   #1
Default Tube Preamp Idea
I want to build a 12AX7 based tube preamp, and since building the circuitry myself for the first time will be quite a lot of painstaking work, I decided to try to figure out some aesthetic qualities first. Here's an idea with a bit of an art-deco spin.
I want it to be small but I think by the time I'm done the unit will be quite a bit larger than I would like it to be. I'm just wondering about peoples thoughts on the design.
-Matt
Old 7th February 2009, 07:23 PM   #2
6f6 is offline 6f6  United States
Where are you going to put the power transformer? I would not try cramming it all in that little box. I say this after having built a nice 6SL7 phono preamp, discovered that I had a bit of a minor hum problem, most likely due to the power transformer. I have yet to rectify the situation, but I sense that I will involve creating a seperate outboard PSU.
Old 7th February 2009, 07:30 PM   #3
Cool design what material are you going to use?
Note to myself: Never again use fingers to check if there still is voltage left in a capacitor...
Old 7th February 2009, 07:30 PM   #4
Old 7th February 2009, 07:43 PM   #5
looks like he's going for an external psu, no?
moulded plastic would be cool, but unfortunally rather expensive
12AX7 is a rather poor choice though (for what looks to be a line amp)
cheers,
mb4b
Old 7th February 2009, 07:44 PM   #6
The PT will be in a plain box down on the floor most likely, either that or in a matching separate box.
Old 7th February 2009, 07:49 PM   #7
you could have one 12:230VAC trannie inside, thus making it possible to use a common 12VAC wallwart on the floor
Old 7th February 2009, 08:30 PM   #8
Very cool, but I shudder to think how much the case is going to cost.. I also think *AX7 is too much gain for a line amp. That a SketchUp model..?
Old 7th February 2009, 09:16 PM   #9
You could carve the case from stacked plywood, and then put a car-type gloss on it.
Of course, this would take a lot of effort to get the surfaces smooth enough, and you'd need to use lots of plastic body filler (P38/Bondo).
Just a thought.
Old 7th February 2009, 11:01 PM   #10
Just a thought.
Thats an idea, but I was thinking along the lines of using a single piece of aluminum for the 4 sides, one for the top and one for the bottom, bending them all at the same curved angle and then putting them together. Won't be easy but I'm looking at the idea.
SE to Balanced tube preamp idea hollow_man Tubes / Valves 33 1st October 2009 07:44 PM
Preamp Idea coldcathode Tubes / Valves 22 16th February 2009 11:59 PM
An UL preamp idea. Shoog Tubes / Valves 15 13th October 2007 07:26 PM
Any idea about this mic preamp zobsky Parts 3 17th May 2007 02:51 AM
Page generated in 0.10507 seconds (78.16% PHP - 21.84% MySQL) with 10 queries
