| diyAudio Sponsor | ||
#11 | ||
Use of an old C-64 power supply found in thrift stores would be beneficial. Once the DC side is bypassed, you have 12V, 3A "wallwart". Plenty of juice to drive the heaters and the step-up transformer. Cheers! |
#12 | |
#13 |
That shape case would be easy to sculpt out of laminated MDF. Start by hogging out the interior space while the 3/4" sheets are separate. Plunge router, 4-holes and jigsaw, etc. Then stack them with glue and a couple of alignment dowels. Last step is to machine the outside. A floorstanding belt sander and spindle sander will be all you'll need. 40 to 60 grit for roughing to shape then hand sand with progressively finer papers. Seal, paint.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#14 | |
Good idea. I'll take a look at what the wood tools are capable of at school. |
#15 | |
Beat me to it.. This method is the second easiest out there next to using a CNC machine and a solid block of aluminum to make a unibody front/top/bottom/sides and a rear plate for that. But that's: 1.) Expensive 2.) Not quite as rewarding when you look at it finished on your mantle.
Wherever you go there you are. |
| SE to Balanced tube preamp idea | hollow_man | Tubes / Valves | 33 | 1st October 2009 06:44 PM |
| Preamp Idea | coldcathode | Tubes / Valves | 22 | 16th February 2009 10:59 PM |
| An UL preamp idea. | Shoog | Tubes / Valves | 15 | 13th October 2007 06:26 PM |
| Any idea about this mic preamp | zobsky | Parts | 3 | 17th May 2007 01:51 AM |
| Page generated in 0.08139 seconds (79.61% PHP - 20.39% MySQL) with 10 queries |
