Finally built my 6SL7, 2A3/6A3 amp
Old 16th April 2003, 04:30 PM   #21
king30 is offline king30  United States
king30's Avatar
Dimitry,
Looks great. What are the dimensions of the case your using?
Old 16th April 2003, 05:38 PM   #22
mig-ru is offline mig-ru  Russian Federation
Well with further inquiries into the problem, moving wires, etc... it looks like the hum might be from the filaments, i think i will try add two 100 ohm resistors between the 6SL7 filament connection to ground and see if that helps. As for the transformers, I got them on Ebay from handwoundtransformers.com, kind of a gamble, but turned out to be very high quality stuff. Last, the dimensions of the chassis are 17"x10"x3".
Old 16th April 2003, 06:10 PM   #23
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Originally posted by Joel
Yuck! 220uF is 180uF too much, IMO.
Why? I agree that 220uF is a good idea, though better placed after the resistor, where power flows into the OPTs.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 16th April 2003, 06:13 PM   #24
Default not filter.
guys it doesnt sound like 120Hz, so I think the PS section will be left alone for now, that's why I think its the filaments, because the primary and HV winding wires are out of the way. thoughts??
Old 16th April 2003, 06:28 PM   #25
Joel is offline Joel  United States
Joel's Avatar
Nope. Move the 800 ohm resistor directly after the rectifier, and increase the choke to 15 or 20 henries. Make both caps 40uF, and you'll have a happy PSU.
I've gone down this road many times, and a 15H choke (or two) usually ends up making things right. Large capacitors never seem to.
Old 16th April 2003, 06:28 PM   #26
Sch3mat1c's Avatar
Then in that case, you can try the hum-bucking arrangements by Steve Bench or try DC fils.
Tim
Old 16th April 2003, 11:10 PM   #27
added the 100 ohm resistors to the 6SL7 filament connections, barely any hum now!!! now i can enjoy it 100%.
Old 16th April 2003, 11:36 PM   #28
fragman56 is offline fragman56
Default Killing the hum
So, Dmitry, way to go!
Am I correct that you put in basically a hum pot (200 ohm) with the wiper to ground and that was successful?
Just curious,
Rick
Old 16th April 2003, 11:51 PM   #29
basically, but not hum pot, just resistors.
Old 16th April 2003, 11:52 PM   #30
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default Rs.
Yup, just the resistors can kill the problem...I fully agree.
Frank
Finally built my 6SL7, 2A3/6A3 ampHide this!Advertise here!
So, I finally built a 3 channel cmoy TheSeekerr Chip Amps 11 23rd October 2008 09:15 PM
Finally built a subminiature guitar amp... now I need help! Hendrixon Instruments and Amps 8 20th March 2007 12:16 AM
I finally designed and built my first crossover! Jim85IROC Multi-Way 17 26th May 2004 07:27 PM
Finally built something :) wintermute Multi-Way 9 14th February 2004 12:25 PM
finally built a gainclone nobody special Chip Amps 5 27th January 2004 08:32 AM
Copyright ©1999-2017 diyAudio
