I have a pair of Manley Reference Compact 160 W monos. One of them developed constant crackling/sputtering noise mixed with periodic noise that sounds like a static discharge. It does not look like a tube or a plate resistor problem. As soon as I install one output tube in any of 4 sockets the amp starts producing this noise. The same tube is dead quiet if I install it in my other amp. I don’t think that it’s a failing cap in the power supply either because I don’t hear any hum/buzz. Suggestions are welcome with many thanks. Alex |
#2 |
Solder joint, loose pin in socket, and coupling cap would be the first three places I'd look, assuming you've truly eliminated the tube as a possibility.
If there's a sucker born every minute, where do the rest of them come from? |
#3 |
Pull the input tubes and see if it still does it.
Mother always said there'd be days like this, so I'm just Hanginon! |
#4 |
It’s very unlikely that its a socket or capacitor since the amp makes noise when I put one tube in any of 4 sockets. One or two sockets can fail at a time but not all of them and the same with coupling capacitors. I also forgot to mention that from time the amp blows B-fuse and yesterday it blew main fuse. However it still working after I replace blown fuses. |
#5 |
It makes the same noise when I pull the input tubes.
#6 |
I'm starting to think bad electrolytic in the B+ HV or bad electrolytic in the B- bias supply.
Do you have a schematic you can post?
#7 |
I isolated one problem- a faulty output tube. I replaced it. Now when I pull input tubes the crackling noise is gone but I can hear some buzz which it s not as loud (I can hear it only 1-1.5 ft from a speaker) as was the noise from the faulty output tube. When I put input tubes back the noise is the same as it was with bad output tube. It does not look like input tubes are bad. When I put them in my second amp they are pretty quite there.
I isolated one problem- a faulty output tube. I replaced it. Now when I pull input tubes the crackling noise is gone but I can hear some buzz which it s not as loud (I can hear it only 1-1.5 ft from a speaker) as was the noise from the faulty output tube. When I put input tubes back the noise is the same as it was with the bad output tube. It does not look like input tubes are bad. When I put them in my second amp they are pretty quite there. Unfortunately I don’t have schematics. |
#8 |
I just realized that I made a mistake. When I said that I pulled input tubes indeed I pulled both input tube and driver tube. When I pull only input tube the noise get louder. Crackling noise is gone only when both input and driver tubes are pulled.
| Maplin 160W (225W) bipolar amplifier design | bluevanman63 | Solid State | 74 | 4th May 2013 03:42 AM |
| Mono 160W Aleph-X towers | Wes Marquenie | Pass Labs | 20 | 28th November 2005 03:05 PM |
| Compact All-In-One Chassis Design with good ventilation. And low noise, Not a Schemat | Layberinthius | Tubes / Valves | 13 | 29th February 2004 01:35 PM |
| manley mic pre | ben goh | Tubes / Valves | 2 | 10th September 2002 01:40 PM |
| Page generated in 0.09792 seconds (100.00% PHP - 0% MySQL) with 9 queries |
