Stereo Buffer with a single twin triode - Page 3 - diyAudio
Old 8th February 2009, 02:22 PM   #21
Brit01 is offline Brit01  United Kingdom
Thanks Eli.
Was this what you had in mind?
File Type: jpg stereo buffer with lm317 ccs modified.jpg (23.7 KB, 830 views)
Old 8th February 2009, 02:36 PM   #22
Thanks Eli.
Old 14th February 2009, 11:33 AM   #23
(available from Ebay seller Audiotek *** - a wellknown scammer)
Well I received my first Audiotek package finally. Got 3 more packages being shipped.
Packed in a little plastic storage case (various Wima caps). Everything fine but the smaller wima's, 0.47uJ100 do not have Wima written on them. Still the same colour but not sure if they are fakes.
Modified circuit with the CCS LM317. Really not sure if its incorporated correctly for a CF.
Have a designed this correctly?
File Type: jpg stereo buffer with lm317 ccs modified.jpg (23.7 KB, 750 views)
Old 14th February 2009, 01:18 PM   #24
Originally posted by Brit01
Thanks Eli.
Yes, it is. However, I have not changed my mind about 10M45S vs. LM317.
Eli D.
Old 5th April 2009, 12:51 AM   #25
Maybe a dumb question.
I am building a simple CF (point to point) with Bas's psu to supply the B+ to 2 x 6N1P's.
I'm unsure of the connection of the B+ to the plate pin 1.
Do I need a cap running to ground before pin 1 or can it be a direct connection from the B+ out of Bas's psu to pin 1?
Old 5th April 2009, 04:30 PM   #26
leadbelly's Avatar
By "Bas' psu" I assume you mean the power supply that was in the Aikido PCB group buy? Then no, you don't need another filter cap, there is already one at the output (after the resistor).
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 5th April 2009, 05:01 PM   #27
athos56 is offline athos56  United States
athos56's Avatar
I'm a little late in chimeing in, but, I used a choke with a DCR = to my cathode resistor's value (1k in my case) and enjoyed the outcome. As in, I repaced the Rk with the choke. I got the idea from the Glassware/Tubecad site, great resource.
Athos
Old 5th April 2009, 05:26 PM   #28
Hi leadbelly. Yes the psu from his Aikido group buy.
Looking at the schematic below I can omit C1 then?
Also I see on JB's Aikido design he has a cap, C6, to ground from B+ before the plate. What is the purpose of this?
Old 5th April 2009, 06:05 PM   #29
athos56's Avatar
Isn't that to provide decoupling between the halves of the tube?
Old 5th April 2009, 06:15 PM   #30
Sorry C5 I meant.
question about twin triode tubes Nihilist Tubes / Valves 2 19th February 2009 04:39 AM
Any subs for 6N1 & 6N2 twin triode valves? rcavictim Tubes / Valves 39 20th April 2005 02:19 PM
mmm.... zero-bias class B twin triode amp Circlotron Tubes / Valves 6 5th March 2003 12:49 AM
Copyright 1999-2017 diyAudio
