diyAudio Sponsor
Old 6th February 2009, 07:03 PM   #1
Send a message via AIM to audiowize
Default Anybody recognize this pentode?
If I gave you the following specs, could you name this pentode? Said unit is "packed in" a triode/pentode, and the pentode looks familiar to me, but I just can't place it:
Max Ratings:
Plate: 400V
G2: 300V
Plate diss: 15W
Screen diss: 2.75W
Average K current: 75ma
Typical:
Plate: 135V
G2: 120V
G1: -10V
Plate Current: 56ma
G2 Current: 3ma
Mu: 6.5
Plate Res: 12k
The low specified plate resistance is throwing me off, otherwise I would be thinking it's similar to an EL84 or maybe a 6AQ5. Maybe more like a bigger version of the pentode in the 6BM8?
Old 6th February 2009, 07:19 PM   #2
Ty_Bower's Avatar
Sounds like a 6LU8 or 6MY8 maybe?
Old 6th February 2009, 09:30 PM   #3
tubelab.com's Avatar
It matches the 6LU8 or 6LR8 exactly. The only difference between the two are the nimber of pins on the base. 6LR8's have 9 pins, 6LU8's have 12. Check out this thread if you want to see them glow:
Spud anyone?
I tried to attach the data sheet, but it is too big. Look it up on Franks:
http://www.mif.pg.gda.pl/homepages/f...135/6/6LR8.pdf
I have seen a tube that contained just the pentode section. I don't remember the number right now but it had an odd 10 volt filament and no 6 volt version.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
anyone recognize this amp? damage Car Audio 22 17th January 2009 11:39 AM
anyone recognize 902-5861? davesaudio Multi-Way 1 25th November 2008 03:26 PM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 05:16 AM
Recognize this Transformer? Magnetmaz Parts 3 16th May 2003 03:16 AM
Page generated in 0.07231 seconds (72.56% PHP - 27.44% MySQL) with 10 queries
