| diyAudio Sponsor | ||
hi
For a ordinary output transfo (not top quality) 2.5k/8 and forget output power and damping factor is it a good idea to drive with a low zout ~300ohm tube like 6as7 to get the best (frequency range) for my "ordinary" transfo or same result with a tube with zout more normal 1000ohm and more. thanks |
#2 |
Distortion, bandwidth and damping could be good, but you might be rather disappointed with power output using that tube. You cant really forget power out as your amp would have to work full blast where another would be coasting...
What is it driving? Im assuming this is single ended.
Be sure your foil hat has a good low impedance ground. |
#3 |
ok there is a relation with bandwidth and low zout
tube and maybe 2 x 1/2 triode for pa=26watt to try more power solution |
#4 |
maybe you could be more clear with your question... kinda confusing.
#5 |
hi mctavish
maybe ? the best way to drive a cheap output transfo is to use a low zout tube |
#6 |
If your talking about SE:
2.5k is a pretty good load for 1/2 of a 6as7. It's possible to extract the maximum power out of it and give an output impedance below 2ohms with no feedback. For both sections paralleled, 2.5k is too high. You may hit the tubes max voltage rating before extracting the full potential power output. 1.25k is the highest I'd go for both sections parallel. In class A, expect 3-4Wrms output per section from this tube. If your talking about a push pull transformer, 2.5k plate-to-plate would do well. |
#7 |
Low Z wont necessarily gain that much power bandwidth if your being limited by saturation rather than inductance.
| Calculating Zout for Pentode amp with NFB? | Jeb-D. | Tubes / Valves | 32 | 26th May 2012 01:48 PM |
| "Output Transfo + FETs" Amplifier | GlidingDutchman | Solid State | 10 | 7th April 2009 08:32 PM |
| Help for a Output Transfo problem | jogas | Tubes / Valves | 4 | 25th May 2005 11:48 PM |
| Zout adapted for 2 EL34 80W Va=560V | Davidakosa | Tubes / Valves | 2 | 29th July 2004 06:56 PM |
| Time for low Zout preamp | argo | Tubes / Valves | 40 | 11th December 2002 11:58 AM |
| Page generated in 0.09763 seconds (65.88% PHP - 34.12% MySQL) with 10 queries |
