diyAudio Sponsor
Old 5th February 2009, 04:25 PM   #1
Default BB 1702 DAC + transformer I/V ?
Hi guys,
Just purchased a pair of Denon DCD1450AR used ( one for me another for my friend). I like it because the Alpha Processor.
They use one BB 1702 for channel.
I was looking on the Sowters page where he has a transformer 8347
specific for 1702.
http://www.sowter.co.uk/specs/8347.htm
I am worried from that frequency graphs, do not seem to my inexpert eyes the best thing one can expect.....
It is slightly rising with frequencies... ( ok vertical division is expanded).
One more, I do not have understood if using a more little value for resistor , performances on the bass are improved ?
What is maximum value that I can use ? 100 ohm or more?
Thanks,
Paolo
Old 5th February 2009, 04:44 PM   #2
analog_sa's Avatar
Default Re: BB 1702 DAC + transformer I/V ?
Originally posted by inertial
Hi guys,
+-0.25db not good enough? To me it seems like a pretty nice transformer. Max value of resistor will depend upon the dac and generally lower values == lower distortion. Cannot imagine why would you want 100ohm or more. It also appears that the transformer core will start saturating above 2mA into 25ohm.
Old 5th February 2009, 04:58 PM   #3
Default Re: Re: BB 1702 DAC + transformer I/V ?
You are right, maybe I can tolerate it! :-)
Me too seems nice for about 50 pounds!
[i]
Max value of resistor will depend upon the dac and generally lower values == lower distortion.[/B]
Distortion of the DAC , am I right?
[i]
Cannot imagine why would you want 100ohm or more.[/B]
Because I want more Volts!
[i]
It also appears that the transformer core will start saturating above 2mA into 25ohm. [/B]
OK, I understand nada of transformer..
What happens if I put 100 ohm instead 25? ( apart 4 x Volts)
Is it the frequency response the same ?
Thanks ,
Paolo
Old 10th February 2009, 01:55 PM   #4
Ouch! Maybe now I have realized.........
It is no possible employ a resistor > 25 ohms because the transformer
will go in saturation , am I right?
If my calculation is correct, with 25 ohms you will have about only 400mV on the secondary .... ie -12dB than standard CDP output level
Do you know a different transformer ( Lundhall maybe ?) that can tolerate a bigger resistor thus give me a superior output level with the same bandwith ? ( mmmmhhhh a lot of bucks I suppose but! )
thanks,
Paolo
Old 10th February 2009, 03:21 PM   #5
edit:
No, 400mV is about -14 dB ( 1/5) respect 2V
Paolo
Old 11th February 2009, 01:46 PM   #6
Please kind guys,
can you suggest me a very good trasformer ( european if possible) capable to tolerate
a bigger I/V resistor , to say 100-200 ohm, in order to achieve a level on the secondary about 2 Volt?
Very thanks for the help,
Paolo
PCM 1702 I/V Stage schmike Digital Line Level 9 20th June 2009 08:32 PM
Help needed to find PVM 1702 Alexiss Digital Source 9 19th August 2006 09:03 PM
my new diy toy. PCM 1702. tube-lover Digital Source 6 3rd July 2006 01:17 PM
Four BB pcm 1702 Stones Swap Meet 5 30th May 2005 09:31 PM
BB PCM 1702 vs 1704 A 8 Digital Source 17 27th March 2003 11:22 PM
Page generated in 0.09873 seconds (76.29% PHP - 23.71% MySQL) with 10 queries
