diyAudio Sponsor
Old 5th February 2009, 04:58 AM   #1
wrenchone's Avatar
Default Triode Connected 6BK5
Has anyone tried this and can enlighten me on triode connected characteristics?
Old 5th February 2009, 01:12 PM   #2
Tom Bavis's Avatar
No, but I'd compare it to 6W6 - may be similar.
Old 5th February 2009, 03:59 PM   #3
smoking-amp's Avatar
The 6BK5 has a much lower gm2 than the 6W6. Can compare the g2 curves on the GE datasheets for them both. The 6W6 is rated at Mu_triode of 6.2 and I see Mu 24 scribbled in on my 6BK5 datasheet. I haven't tried this tube, even though I've got a few in a box. So probably was a calculated Mu from the curves.
Looking on the left/ bottom of page 3 of the GE datasheet for the 6BK5: the plate current versus grid voltage allows one to check Mu versus plate voltage (for constant current). Looks like the Mu drops some at low plate voltage (spacing between curves increases some for the 100V curve). But these curves are measured at constant (250V) g2 voltage, so this may just be an affect of the increasing screen current in pentode config. at low plate voltage. The plate characteristics curves at the top of the page show an obvious upswing in screen current around 100 Vp.
Don
Ohms Law V = I R
Max B+ for triode-connected KT88 SpreadSpectrum Tubes / Valves 32 5th December 2007 04:08 PM
8417 triode connected tube data rhcclark Tubes / Valves 0 5th May 2007 03:05 PM
6AU6WA triode connected as a line amp? grhughes Tubes / Valves 13 10th October 2006 01:17 PM
Measuring Triode-Connected Pentode Curves rdf Tubes / Valves 23 11th April 2006 09:29 PM
Triode connected SV6550C with 500V HT sajti Tubes / Valves 9 18th May 2005 07:12 PM
Page generated in 0.05537 seconds (78.70% PHP - 21.30% MySQL) with 10 queries
