diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   VR tubes in single ended circuits (http://www.diyaudio.com/forums/tubes-valves/137891-vr-tubes-single-ended-circuits.html)
Jeb-D. 4th February 2009 12:21 AM
It seems that VR tubes can be a little tricky to incorporate as regulators in single ended designs. I get a significant speaker pop when the ionization voltage is reached on power up (because it quickly drops to the regulation voltage).
I know others are using them, but I have yet to hear anyone mention similar problems. The only solution I can think of is to apply B+ before the heaters. Though this is generally bad practice. Anyone got any tricks?
For the time being, I'm using a Zener diode. Though it would be cool to use a VR tube instead (they look cool and I have a quantity of them).
dsavitsk 4th February 2009 12:31 AM
Mine pops too. So, no help from me other than you could use a timer to connect or disconnect the speakers. And, I have also resorted to zeners in places.
Copyright 1999-2017 diyAudio
