diyAudio Sponsor
Old 3rd February 2009, 01:15 AM   #1
Default Dual supply...
... in a tube preamp... So, I do it as with single supply, or do I have to trim some bias to grids? Thanks!
Old 3rd February 2009, 01:43 AM   #2
Iain McNeill's Avatar
Can you post a schematic of your pre-amp?
You don't give us enough information
Old 3rd February 2009, 10:53 PM   #3
Well, it will be like any guitar amp preamp, but I want to build some hybrid, so, with SS output, I have dual supply, 50Vdc, and I have a couple of 6SN7 and a pair of ECC84 (yes, I know, they're not for audio purposes...) and I wanted to make them work with that supply, not just single 50V dc... would be like the old-style marshall preamp, like plexis.
Old 5th February 2009, 10:32 PM   #4
So, anyone?
Old 5th February 2009, 10:43 PM   #5
6SN7 does not compute at those voltages, well maybe they do, but they don't sound good. ECC88 types would be better and could probably be run of a split rail if you like
however, since it's for a guitar amp, you might like the distortion and limited swing a 6SN7 with a low B+ will give. i'd forget about curves and such and just throw a 10k on the plate and a 1k on the cat and take it from there
i've never seen any old style amp run off anything like 50V, btw
cheers,
mb4b
Old 5th February 2009, 10:55 PM   #6
Banned
2 posts, you still don't give us enough information. This is plain rude.
Post something sensible, like a drawing, since you obviously got no talent for explanation.
No wonder you not getting any replies.
w
Old 6th February 2009, 01:12 AM   #7
That was kinda rude, wakibaki, it's pretty simple!
2 or 3 triodes stage, b+ to resistor to plates, cathode to resistor to b-, and don't know what I can do with grids! 6SN7 are pretty linear, so, make them work with 100V would make them distort easily, right?
I could use some trimmer as plate resistors... maybe...
Ok, I'll post some drawing later.
Old 6th February 2009, 01:44 AM   #8
Oh! I see. You're trying to run a tube amp off your dual 50V power supply.
Putting the two outputs in series would give you 100V to work with. I would ignore ±50 with a 0V tap and just think of it a 0V and +100V.
Can you make a tube preamp work on 100V? I'm sure the answer is yes. Someone else is probably better able to suggest designs than me.
Old 6th February 2009, 08:39 AM   #9
Banned
I'd go for something like this:-
You can steal the tonestack values from a fender champ, the data is for 6sn7, 90V is close enough.
w
Old 6th February 2009, 12:22 PM   #10
Great data! The fact is I want to use a mosfet power amp, with 50V dual suply, and that's why I wanted to use dual supply! Tubes can run with lower voltages... they just become less linear...
Thanks!
Symmetric supply or dual supply? JWFokker Parts 32 11th August 2011 08:29 PM
Dual supply for LM1875 split supply dovganj Power Supplies 30 6th November 2009 03:19 AM
Dual supply for DOZ / JLH? jnb Solid State 2 20th October 2007 12:48 PM
Supply for dual mono pre-amp Tex Houston Power Supplies 3 17th May 2007 09:26 PM
Dual 15V Regulated Supply ble0t Parts 7 1st September 2004 01:28 AM
Page generated in 0.09591 seconds (75.36% PHP - 24.64% MySQL) with 10 queries
