diyAudio Sponsor
Old 1st February 2009, 07:51 PM   #1
Default adding output tubes etc to pre amp
I have an old cj PV2AR preamp. I wanted to make a st-70 type kit amp to go with it and give it to my daughter.
Knowing that as a student she wont have a lot of room for a while, I was wondering if you can use the pre amp as the front end section of a tube amp, and make my own "integrated " tube set up
Old 2nd February 2009, 06:02 PM   #2
leadbelly's Avatar
Yes, it most certainly can be made to work, although it may not be practical. Just as with any "which amp should I build" question, you need to give us more details about what speakers you intend to drive and so on. Do you have a schematic for the preamp? Not all preamps have a lot of gain or current drive capability so this will likely be your limiting consideration.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Adding more power tubes and make a tube amp switching them? Nicko_Lps Tubes / Valves 3 7th January 2009 12:31 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Adding a sub output to a SI jarros Class D 4 21st April 2005 08:22 PM
Adding output transistors Number04 Solid State 9 15th November 2003 11:49 PM
Adding a Sub output... sum the two inputs? PaulHilgeman Solid State 9 25th February 2003 04:51 PM
Page generated in 0.05918 seconds (72.12% PHP - 27.88% MySQL) with 10 queries
