| diyAudio Sponsor | ||
I just picked up a Bogen CHB 10A PA amp and the imputs are a phono jack, and a screw on mic. input. How do I wire a 1/4" jack when the phone input has one wire and is grounded to the chassis. And the mic. input has three wires. Also the speaker output jack has three wires. I know there can be high voltage and need to be very careful. This has not been plugged in in years and I know how to use a screw driver to discharge the caps. I am also going to replace the caps so if anyone know a good source for these let me know. I know there are some threads on this sight for upgrades for this model for conversion to a guitar amp but I don't feel able enough for some mods. I can replace caps and resistors, and have done that before.
Thanks for any help. consoleb |
#2 |
Here is a schematic. http://schmarder.com/radios/schemati...n-chb10a-4.jpg
The microphone input is the one I would use. Be careful not to overdrive it. The schematic shows a standard output transformer. Just avoid the 25 and 70 volt connections. Use instead the movable lead attatched to pin 2. You can use the connections on pins 1 an 2. The microphone input has two connections only. I sincerely hope this helps. |
#3 |
Thank you so much.
Consoleb |
#4 |
I want to replace the mic and phono jack with 1/4" input jacks for guitar, but when I went to radio shack they sold (1/4 Mono OPEN CIRCUIT jacks , and 2 conductor CLOSED CIRCUIT jacks. Which do I use open or closed circuit. Also as I stated before the existing phono jack has only one wire to it and is grounded to the chassis, and the mic input has three wires connected to it.
Thanks consoleb |
| newbie questions on Bogen M330A repair | GregC81 | Tubes / Valves | 3 | 23rd November 2007 07:50 AM |
| Bogen CH8 | imix500 | Tubes / Valves | 1 | 22nd April 2006 04:03 AM |
| Bogen PA--->Guitar Amp, few questions | Turbo7MN | Tubes / Valves | 100 | 5th April 2006 01:41 AM |
| Bogen DS-225 | lpd | Tubes / Valves | 2 | 18th December 2004 05:18 AM |
| Bogen help | sickss | Tubes / Valves | 0 | 2nd June 2004 01:25 PM |
| Page generated in 0.07794 seconds (71.14% PHP - 28.86% MySQL) with 10 queries |
