| diyAudio Sponsor | ||
I'd like to pick up one or more books of tube data so I can have that information right in front of me instead of looking up certain tubes on the interwebs. Are there any versions that should be sought out or any that should be avoided? Or are they all basically the same?
thanks |
#2 |
An early (1940 or so) and late (late 1960's) RCA manuals should cover most everything you need - Sylvania's '40s manuals are also good for the early tubes. GE's were a "summary" type - one or two lines of data per tube, but of course they could fit more numbers in that way...
#3 | |
Much more information is available in the RCA HB-3 handbook series. This is a multi volume (5) small loose leaf, but very thick, set that provides more curves and covers receiving, industrial, transmitting, cathode ray and other special types. One such volume is shown below. These have become rare and difficult to find. But RCA didn't make everything. To be well rounded you'll want handbooks from at least several others like Amperex, Siemens or any other European maker that you can find. Finally many, if not all, of the once big American tube manufacturers published large loose leaf binders of tube specifications. These have become very rare, but once in a blue moon, you might find one or two on eBay for big money. Fortunately for me, I've been around long enough to have collected many of these. However I find that, for the most part, the common small tube manuals are the ones I use most. Victor
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#4 |
The one available through Antique Electronic Supply is a good one and has the most used tubes found in experimenter junkboxes.
Cheers! |
| data sheets for 7239 and 8068 | nhuwar | Tubes / Valves | 3 | 20th May 2008 09:05 PM |
| Where to find data sheets? | Zap | Tubes / Valves | 4 | 20th November 2007 06:38 PM |
| Help me read tube data sheets | Andersen | Tubes / Valves | 5 | 18th April 2007 01:43 AM |
| M5238 data sheets??? | Christer | Parts | 5 | 30th March 2003 04:07 PM |
| Japanese data sheets | HarryHaller | Solid State | 1 | 16th May 2002 06:54 AM |
| Page generated in 0.07078 seconds (74.46% PHP - 25.54% MySQL) with 11 queries |
