Need a bias supply  how??
Old 1st February 2009, 09:47 PM   #11
Burnedfingers is offline Burnedfingers  United States
Craig mentioned in an email a circuit that would work.
I did some digging and found this circuit in "Principles of Power"
page 5-29
I will include it for discussion.
Old 2nd February 2009, 10:53 AM   #12
I've used a 25.2V, 2A Radio Shack tranny which can generate up to -66V with a doubler circuit. And it can also serve as some nice clean DC for the preamp tube filaments.
Can you tell me how to do this? I've never done a doubler circuit before and certainly not a negative supply. Could you post your circuit and parts values?
In a prior post I posted a circuit that made a negative bias supply off of the secondary of the power transformer. This so far has not prompted any discussion as to its merits so I guess its not the thing to do and the Radio Shack route is the way to go.
Old 2nd February 2009, 12:09 PM   #13
Nevermind
I remembered how to do a doubler and built up a -70 supply.
I am howerever trying to remember a schematic I saw one time that used a 6X5 by putting the 400volts into the cathode and getting a negative supply off the plates. Any ideas on this?
Old 2nd February 2009, 12:28 PM   #14
45 is offline 45  Italy
45's Avatar
Originally posted by burnedfingers
http://www.aikenamps.com/BackBiasing.html
This will only give me -9--13volts if I am looking at it correctly and I need to bias the EL34's.
Diode pump circuit? Don't know what you mean.
I was thinking that I saw a circuit somewhere that used a voltage divider off the AC and then one diode and then went to the bias circuit. Maybe I'm wrong :
I don't have the room for even a small transformer on or under the Dynaco chassis.
That is just an example.
Back-biasing is a good solution if you go for Class A1 or moderate Class AB1 operation (i.e. the anode current at max output should not be greater than the idle current). In that case it is almost as good as a classical fixed bias. Actually this is more the case for triodes or triode-connected pentodes.
For UL or pentode connections you always have a more variable g2 current which can easily double at max output.
It will give you just any voltage you need by changing the resistor that connects the center-tap to the ground (according to the total voltage you have and the currents you need). The higher the voltage drop the lower the effective anode voltage supply will result, of course.
You have just to find a good quiescent point for your amp and the "right" rectifier in order to get the supplies you need.
For example, triode connected EL34's at max. plate dissipation require 400V anode voltage and 30V bias. So you need at least 430 Vdc.
In that case the idle current should be 70 mA per valve. Then, to get 30V bias, the resistor should be at least 215 ohm. With a slightly higher value for both total DC supply and drop resistor, you will have some additional drop which will allow for some regulation (together with additional filtering).
45
Old 3rd February 2009, 03:01 AM   #15
Can someone explain the pros and cons of using a rectifier tube as a means of a negative bias supply?
I saw a schematic of a Grommes 215BA that uses a 6X5 by putting an AC voltage to the cathode and getting a negative voltage off the plates. I cannot however see the value of the cathode resistor on the schematic but I think its 10K.
Old 3rd February 2009, 09:18 PM   #16
kmaier is offline kmaier  United States
kmaier's Avatar
Default Re: Need a bias supply how??
I have an HP transformer that I am using in a Dynaco stereo 70 that I am putting together. It doesn't have a bias supply tap.
Can I make one by coming off one of the AC secondaries? Its 435-0-435 AC secondary.
Can someone help me out here?
I used a very simple setup in a design I did in the early 90's.... a 0.03uF film cap (orange drop) from one of the secondary ends in series with a 43K resistor to ground. At the junction of the 0.03uF cap and 43K resistor, take a diode for rectification to a 50uF cap to ground. From this point, use a series resistance of about 40K between a pot and fixed resistor(s)... take your adjustable bias for the pot wiper to another 50uF cap... it will easily bias a pair of EL-34 tubes. It's been working on several amps for over 15 years... has never failed and doesn't make a lot of heat either.
Regards, KM
... just because you're paranoid, it doesn't mean they're not after you...
Old 4th February 2009, 12:52 AM   #17
CarlyBoy is offline CarlyBoy  Canada
Love that amp - not too many commercially available triode-wired 807 designs out there. Here's the bias scheme. Cathode resistor (R41) is actually 68K.
Old 4th February 2009, 02:46 AM   #18
Thank you for posting a clear image of the schematic. Do you happen to know if the bias scheme would cause any ill effects such as hum?
Old 4th February 2009, 11:14 AM   #19
CarlyBoy,
Could I have a copy of your schematic?
Thanks,
Joe
Old 4th February 2009, 11:33 AM   #20
vitalstates is offline vitalstates  United Kingdom
vitalstates's Avatar
here are the old-school variations...just google on fender bias circuit or marshall bias circuit etc
Need a bias supply  how??Hide this!Advertise here!
DHT bias and filament supply in one? dsavitsk Tubes / Valves 7 10th July 2009 04:50 AM
Bias Supply resistors AmpBuilder225 Tubes / Valves 14 19th April 2009 12:34 AM
Bias supply idea astouffer Tubes / Valves 15 2nd October 2008 03:12 AM
Ideal bias supply? ak_47_boy Planars & Exotics 2 30th October 2006 07:23 PM
Bias supply question kianbach Tubes / Valves 0 2nd May 2005 11:33 AM
Copyright ©1999-2017 diyAudio
