making two minibloks for stereo
Old 31st January 2009, 11:51 PM   #1
watasnake is offline watasnake  United States
Default making two minibloks for stereo
How would I go about making two miniblocks by Fred Nachbaur into a stereo set? I have little electronic experience. What about controling both. Should I use a pre and treat each as a single. Then how do I get around the volume. Oh, so many questions. I want two monoblocks with one volume control. Thats as simple as I can put it. Here is the amp I am talking about - http://www.dogstar.dantimax.dk/tubestuf/miniblk1.htm
Old 1st February 2009, 01:02 AM   #2
chrish is offline chrish  Australia
chrish's Avatar
If you have mono blocks then you will just use two for a stereo pair. Connect to a pre-amp for volume control. If you do not have or want a pre-amp, then build the two mono blocks in the one chassis with a stereo log pot volume control. If you build the two in the one chassis you would also be able to save some cost and complexity by building one power supply (obviously it must have twice the current handling capacity of a power supply designed to power one channel only).
Chris
Old 1st February 2009, 04:50 AM   #3
thanks Chris, I was looking for the stereo volume pot. I think I'm OK now.
making two minibloks for stereoHide this!Advertise here!
Stereo in/multiple Stereo outs Circuit MartinByrne Everything Else 3 7th May 2009 02:11 AM
Reprocessed for stereo, Rechanneled for stereo and Duophonic oldheathkitphil Analog Line Level 3 29th February 2008 02:20 PM
making sub with stereo amp kdlsrinu Subwoofers 0 24th August 2005 07:58 AM
Making home stereo, cheap power + quality??? da_madaxeman Solid State 18 21st August 2003 01:01 PM
How do I wire stereo headphones on a stereo tv? hike1 Everything Else 2 10th September 2001 03:22 AM
