| diyAudio Sponsor | ||
Can anybody send me a link that explains how to calculate choke loads?
Thanks, Dirk |
#2 |
Go to vt52.com . Look at diycorner , tip and tricks , software tools and open platechoke.xls .
316A |
#3 | |
This was written w/r/t/ attenuators, but the calculation is the same. From http://www.intactaudio.com/atten_FAQ.html
http://www.ecpaudio.com |
#4 |
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#5 |
I got so far: Using a PL509 in Screen drive, I get Rp = 8000 Ohm. I want the -3 db point at 50Hz, this means, I have to use a 25 Henry choke Electrostatics need push-pull, so my choke must be wound with opposite coils, having a total of 50 Henry. If I use 2500Volt as a power supply, I assume that I negnect the Ohmic resistance (Is this correct???). The tube can handle 40 Watt dissipation. So 15mA of standing Current would be ok??? I haven't found any mu values for the tube in ETM? Somebody has values, comments to my thoughts??? Regs, Dirk |
#6 | |
316A |
#7 |
As I mentioned in your other thread, Jack at Electra-Print have made a PP-pair for me.
About current you must know the ESLs capacitance at 20kHz to calculate. Also I doubt EL519 can take 2,5kV continous even at low currents.
Brgds Lars |
#8 |
I prototyped a PP choke-loaded amp for my ESLs a couple of years ago- if you have a step-up transformer (I used the LF one for the Acoustat MK121), just turn it around and use the secondary to load the tubes. The primary can be left open or be shunted with a damping network. Balanced, center-tapped, known-good at high voltage, known high enough inductance for the panels, what's not to like?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#9 |
Be sure your foil hat has a good low impedance ground. |
#10 |
@316a: I don't understand. I could understand if you used the EL519 as pentode. So I would take the signal from the anode leads...
But you connect the UL leads with the valve anode, and the esl with the Anode leads... In case of a screen drive, I would only use the anode leads... @revintage: Curcio uses pl509 as srpp with 4kv, other designs with more than 5kv... (SRPP) I took the choice of 2,5kv and 15mA because of max. dissipation... @sy: Isn't it a problem that the primaries increase maybe capacitive effects??? Why should I use damping elements? @all: So all of you prefer choke loading to srpp??? Reasons??? Regs, Dirk |
| Plate Choke calculation | swordsman | Tubes / Valves | 7 | 8th April 2008 12:42 AM |
| parafeed plate choke calculation | alexg | Tubes / Valves | 3 | 15th November 2007 04:12 PM |
| GZ34 anode load resistor calculation - help? | coolmaster | Tubes / Valves | 16 | 3rd February 2007 04:42 AM |
| Choke load for CCS-XBOSOZ ??? | Magura | Pass Labs | 6 | 19th September 2004 08:13 PM |
| Choke Load or WOT | Mas Penk | Tubes / Valves | 17 | 13th February 2004 01:57 PM |
| Page generated in 0.10687 seconds (83.13% PHP - 16.87% MySQL) with 10 queries |
