Old 14th April 2003, 05:52 PM   #1
jim is offline jim  Belgium
Default Battery tubes
I've some 1J6G and 1G6GT battery tubes.
I'd like to use them in my 2A3 amp.
Do you guys have experience with these.
Jim
Old 15th April 2003, 10:48 PM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Sorry. No.
I've looked at the curves for battery valves, and they didn't look promising...
Another way to look at it is to realise that valves are only slightly noisier than transistors, but that they operate with x10 supplies, which automatically gives them greater dynamic range. Battery valves don't have this advantage.
Still, if you've got them, try them out, and see what happens.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 15th April 2003, 11:01 PM   #3
diyAudio Senior Member
fdegrove's Avatar
Default LOOSING THE VALVE TOUCH.
Conversely this is why, when transistors, mosfets mostly, are run at higher voltage rails sound much more dynamic and alive.
Frank
Battery Charger for 15V Li-ION Battery Pack ??? Jan Dupont Parts 2 11th April 2009 02:18 PM
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 09:01 PM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 12:37 AM
Any spice models around for AA5-esque battery tubes? aletheian Tubes / Valves 2 30th March 2007 12:35 AM
many new tubes and tubes meter for sale elviukai Swap Meet 4 30th October 2003 09:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
