diyAudio Sponsor
Old 30th January 2009, 03:53 PM   #11
I think I've presented about the ultimate circuit for exactly that.
But I have no proof other than the LTSpice simulation as shown.
However, I lack the skill to explain it adequately. A lot of what
it seems to excel at came as an unexpected bonus surprise.
I have never built one, and as far as I know, nobody ever has.
I've written Broskie to see if he wants to tackle an analysis,
and potentially debunk this idea before it wastes anyone's
time on something that won't actually work.
I am too busy at work to bench this right now. My boss would
tear my head off if I was playing with tubes before my regular
work was completed.
I don't have a DAC like yours, but I have an Tek AFG3252 dual
channel function generator on my desk that can fake it.
Old 30th January 2009, 04:17 PM   #12
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
Look here:
http://www.lampizator.eu/LAMPIZATOR/...Lampizator.doc
Build the alternative setup.( Cathode follower ).
Here his site.
Steel left signal from pin 18 and right signal from pin 12 of the PCM1793.
Old 30th January 2009, 04:40 PM   #13
revintage's Avatar
The outputs from the DAC are at +1,4V DC so this must be handled if you want to directcouple to a tube. The circuit in my post above was adjusted to that specific DAC that where at over +2V DC. It can be fixed.
The Lampizor does not work with diff outputs.
Brgds
Lars
Old 30th January 2009, 05:11 PM   #14
Mine is shown (simulated) handling 10VPP common mode ripple.
Which implies that it can easily handle 5V offset in either direction.
Though it was designed around 2.5V offset. Whatever...
Its clear that this is a much hated circuit, though no-one has
ever built one or rationally debunked it. Lets keep it that way.
Old 30th January 2009, 05:13 PM   #15
I would like to use a 6dj8 tube to build this. What adjustments need to be made for the 1.4 v 1793 DAC?
Old 30th January 2009, 07:31 PM   #16
revintage's Avatar
This should do it. Signal out will only be 0,4Vrms, THD below.05% with falling overtonespectra.
It looks great when simmed but as kenpeters I have never built it.
Contact sunrise to hear if it it worked like he wanted.
Brgds
Lars
Old 30th January 2009, 07:54 PM   #17
Nice! Thanks. Any kind of spec on that LED? or Just a regular instrumentation red type? I will check with Sunrise.
Old 30th May 2011, 03:36 AM   #18
alevans51's Avatar
Default BURSON AUDIO BUFFER
Consider using the Burson audio buffer instead of an electron tube.
Tubed IR spectrophotometer 7n7is Tubes / Valves 17 21st November 2009 04:23 PM
PCM1793 DAC chip dublin78 Digital Line Level 0 9th June 2009 08:32 AM
Tubed Expression Pedal mashaffer Tubes / Valves 7 10th April 2007 02:31 PM
Tubed HU EvilGenius Car Audio 5 26th May 2006 09:54 PM
HELP!! pll1700+dir1703+pcm1793 DAC kafka Digital Source 12 28th September 2004 09:43 AM
Page generated in 0.09349 seconds (78.46% PHP - 21.54% MySQL) with 11 queries
