| diyAudio Sponsor | ||
I'm in the process of trying to design a channel strip and have a pretty basic question. The channel strip will be an aikido microphone preamplifier with it's outputs going into a basic passive equalizer then back into an aikido amp to makeup the loss through the eq.
My question is about the input transformer. What is the difference between using a high ratio transformer like a 10:1 and a low gain circuit and using a low ratio transformer like a 2:1 and a high gain circuit. What are the sonic differences and what would prompt using one or the other? Thanks. -Joe |
#2 |
Anyone?
#3 |
The devil is in the details. How about giving us some, like schematics?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 |
You might want to visit the Jensen Transformers website and download some of their application notes. They offer a range of mic input, line input, line output and level matching transformers and have very detailed application notes. Without knowing any specifics for your mic preamp requirements (i.e., input impedance, phantom power requirements, overall gain requirements, amplifier circuitry, etc.) it's difficult to give you much meaningful feedback. Take a look at what Jensen offers... then decide on what route to take. Suggest you start here:
http://jensentransformers.com/mic_in.html Regards, KM
... just because you're paranoid, it doesn't mean they're not after you... |
#5 | |
#6 |
Ok, schematics. http://www.tubecad.com/2004/blog0011.htm that's the circuit i'm speaking of. I didn't know what the difference would be between using a low ratio transformer with a 12ax7 or using a high ratio transformer with a 6sn7 or something with even lower mu.
#7 |
As has been noted already, it's all down to impedances.
A turns ratio of 10:1 will result in an impedance ratio of 10(squared)... i.e. 100:1 . This means that a low impedance source can appear as a high impedance to the amp stage input once the transformer is inserted. This large impedance then has to drive the Miller capacitance of the input tube, and it is likely to seriously limit the bandwidth. My money would be on using the lowest turns ratio possible at the input transformer, and then a high gain tube (with the proviso that the tube have linear characteristics). |
| Preamp Design | steevo | Solid State | 8 | 10th October 2007 09:11 PM |
| HELP PLEASE - with preamp design | soundbadger | Tubes / Valves | 5 | 2nd October 2007 06:38 PM |
| Preamp PSU Design Help | DoomPixie | Tubes / Valves | 18 | 5th July 2005 02:08 AM |
| Preamp design question -- where to put buffers? | gretzteam | Solid State | 6 | 1st March 2002 04:36 AM |
| Preamp design | Alex | Solid State | 13 | 11th October 2001 10:49 AM |
| Page generated in 0.09442 seconds (79.82% PHP - 20.18% MySQL) with 10 queries |
