diyAudio Sponsor
Old 27th January 2009, 09:57 PM   #1
Default amp dead?
well i'm still working on the problem thought i'd figured it out but guess not. i had to literally pry one of the 6l6 tubes out of the socket, there was all kinds of hard tacky looks like pine rosin all over the bottom of the tube. thought a capacitor had went out but that aint it. could this stuff come from the tube? anyway i was cleaning it off of the tube base and pins when the center pin broke loose. it's still attached but will this cause a problem? thanks for everyones help.
Old 27th January 2009, 11:08 PM   #2
kevinkr's Avatar
Any transformers nearby? And is this stuff also all over the board? Wondering if the stuff came from somewhere less obvious like from an output or power transformer and ran across the pcb..
Ought to have posted to your existing thread rather than starting a new one.
Perhaps a mod could combine this with the existing thread here:
http://www.diyaudio.com/forums/showt...61#post1726461
www.kta-hifi.net
Dead AKG P 8E with X 8S R Bernhard Analogue Source 10 2nd April 2008 10:55 AM
dead amp ddoyle Chip Amps 20 30th July 2007 01:30 AM
Dead Amp?? Shim Solid State 12 5th June 2007 04:00 PM
Nak mb-70 dead ? MadMutt Car Audio 10 5th April 2007 03:18 AM
is my amp dead? :( torxim Car Audio 5 18th September 2004 10:37 AM
Page generated in 0.05695 seconds (78.39% PHP - 21.61% MySQL) with 10 queries
