| diyAudio Sponsor | ||
Hello,
I've got a Scott LK48 that uses 7189s in the output and measures +458v on the plates. I'm currently using a quad of 7189s branded as Mitsubishi, don't know what they really are. I'd like to get another set of output tubes and am looking for suggestions. Wondering how some 6bq5/EL84s might work... +458v is kinda high. Finding NOS 7189s is difficult and they are very pricey. The amp is running a pair of stacked ESL57's. |
#2 |
So how many volts are on the cathode? (assuming cathode bias, could be wrong)...recent amp I did had 415v at the anodes, with 45v at the cathodes (and it's still in AB1, I swear!)...that means the tube is only "seeing" 370v, not 415.
Also, 6p14p-ev. I believe they will work well. |
#3 | |
#4 |
frugal-phile(tm)
fixed bias...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
It is a fixed bias amp and the cathodes are grounded. Not exactly the same schematic that Planet10 shows as mine uses 7199's for the driver splitter, but the output bias is the same.
So how does the neg bias voltage effect the overall plate voltage load? Lets say it's fixed biased at -40v (haven't measured) and the plate to ground voltage on the 7199s is 450v (which it is). Is the 7199 plate seeing a 450v potential or 410v? Or in between? |
#6 |
I've been a bit busy yet to fry some 6p15p in my Fisher.
Need to verify first the "unused" internally connected pins don't short out anything the real 7189s wouldn't. And arrange safety precautions that might protect me and the rest of the amp in case of G2 failure.... XRays of several similar pentodes of this family have been posted to another thread. I don't see any huge difference of internal geomety to explain why some are characterized for higher screen voltage. But it could be some quality of materials or vacuum that isn't able to be seen even by XRay photograph? I still suspect there may be no difference at all. |
#7 |
fixed bias does not affect plate volts. So it's still 450v. The maximum voltage rating is generally anode to cathode (aside from heater to cathode voltage ratings), so if the cathode's at 100v and the anode at 500v, the tube is only seeing 400v. A cathode resistor, a la cathode bias, develops it's bias voltage as a result of the voltage drop across it, and *is* subtracted from B+. This makes the cathode positive leaving ground (where the grid is at) as an apparent negative voltage (with respect to cathode). So you can drop volts by developing some or all of the bias by cathode resistor, but in fixed the tube will "see" 0v at the cathode and 450v at the anode.
#8 |
As I recall, both channels of mine are dropped across one string
of four heaters... But its been more than a week since I glanced at the x100a schematic, I could be imagining something wrong... |
| 7189 or 7819 el84 tube? | papanohn | Tubes / Valves | 6 | 24th March 2007 04:37 PM |
| 7189/7189A Problem | Victoria | Tubes / Valves | 6 | 22nd January 2007 03:08 AM |
| What tube instead of 7189 | jim | Tubes / Valves | 23 | 5th June 2006 10:59 PM |
| "The Fisher" tube amp 7189 output tubes | laflamme | Tubes / Valves | 4 | 28th August 2004 12:40 AM |
| 7189 in pentode mode? | G | Tubes / Valves | 30 | 12th March 2003 04:13 PM |
| Page generated in 0.09354 seconds (77.17% PHP - 22.83% MySQL) with 11 queries |
