diyAudio Sponsor
Old 27th January 2009, 08:01 AM   #1
Brit01 is offline Brit01  United Kingdom
Default What does your Aikido drive?
Just interested in what you are using your Aikido for apart from a headphone amp.
Being a total newbie to this hobby I made the mistake of thinking that my Aikido could be used as a preamp for my SS power amp Just a bit too much gain apparently
Now with a bit more knowledge after swatting up on more tutorials I think I will modify it for headphone use and start on a buffer amp for my power amp. Simple Cathode Follower maybe.
Also starting to gather parts for a simple SE maybe with EL34 or EL84's and 6N6P's as the driver.
So what do you use your Aikido for?
Old 27th January 2009, 09:46 AM   #2
Geek's Avatar
Default Re: What does your Aikido drive?
Originally posted by Brit01
JBeing a total newbie to this hobby I made the mistake of thinking that my Aikido could be used as a preamp for my SS power amp Just a bit too much gain apparently
You just need to use lower mu tubes... 12B4, trioded pentodes, etc.
I've used an Aikido on the bench as a line driver, as well as similar circuits for driving trioded sweep tubes in tests. With the right choice of tubes, it can swing a good amount of volts. I'm rather fond of the 5751 when I need gain and the load doesn't drop below 47K.
Cheers!
Old 27th January 2009, 10:24 AM   #3
Thks Gregg. These have a really low mu I see, 6~. I just bought some 6N6P's for the lower mu but they are not comparable.
I'll see if I can find some on ebay.
In the meantime I'm going to try the Aikido as a headphone amp.
Old 27th January 2009, 10:46 AM   #4
mmm... not so common this one.
I see tubestore has in stock at 7.95 each.
Old 27th January 2009, 04:27 PM   #5
athos56 is offline athos56  United States
athos56's Avatar
I use mine as a front end of a SE KT-88 amp. I like it.
Old 27th January 2009, 06:21 PM   #6
Andypairo's Avatar
I use it as front end in my hybrid amp, followed by a power diamond buffer.
Steve Dunlap's Krill amp is another option..
Ciao
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 28th January 2009, 04:37 AM   #7
minhaj is offline minhaj  Bangladesh
Aikido is a topology you can use it to drive many things. I use it as a line amp to push 2A3 drive 300B se amp.
You can put 10K ohms high quality R in series to input pin of 10K orms volume pot -that will reduce gain significantly, may prove to be OK for your SS amp.
I built 2nd half of the Aikido as buffer and it gave very good result better than anything I built earlier. You can try that.
Old 28th January 2009, 07:24 AM   #8
I might just try that. In fact I have an Alps 10K in the post right now. Should arrive in a week or 2.
I'm still looking for input tubes with a low mu. OlleBolle just reminded me the 12B4 is not a twin triode.
I'm planning to build a buffer using a cathode follower which is what the second half of the Aikido is
Old 28th January 2009, 07:33 AM   #9
Tweeker is offline Tweeker  United States
6080 is a rather low mu twin, probably too low to use in both sections. However as a CF section gain is ~.6 and it can drive very demanding loads.
Another almost heretical thing you can do to reduce gain is apply NFB.
Be sure your foil hat has a good low impedance ground.
Old 28th January 2009, 07:52 AM   #10
Would these be feasible with JB's board 5687 configuration?
More Grunt from Aikido Needed to drive PL509's Philwait Tubes / Valves 5 6th July 2009 08:49 AM
I'm about to drive a stake thru the heart of my Aikido linestage BillEpstein Tubes / Valves 6 15th June 2009 04:39 PM
FS: Hitachi Router and Terk outdoor HD antenna, BD-Rom drive, Xbox HD Drive and more. Dougie085 Swap Meet 0 3rd May 2008 07:31 PM
Idler wheel drive vs. Belt-drive mig-ru Analogue Source 4 3rd December 2003 12:06 AM
Computer Question-Any Problems Transferring Office 97 From D Drive to C Drive kelticwizard Everything Else 12 22nd January 2003 03:34 AM
Page generated in 0.12573 seconds (69.02% PHP - 30.98% MySQL) with 10 queries
