| diyAudio Sponsor | ||
Hi,It's a funny thing to build a hybrid amplifier is small cases.
This model use two vacuum ECC88 as a SRPP preamp.One IC LM4766 as output stage. |
#2 |
Another demo picture.
#3 |
Hi Luck ,
Nice work . Congratulations . I did have the oportunity to service and to listen many hybrid amps , most of them built by the former Counterpoint Company, and all of them did sound very , very nice . I think that yours sounds very nice too , mainly due to the simplicity. IMHO , simplicity is the first goal ,if you want to get a good sound in any Hi-Fi or DIYaudio project . Off Topic : The “ Gotan Project “ is a good “sound” , too . Did you know that Gotan is an anagram of Tango that is the Argentina native rhythm ?? Carlos |
#4 |
Hi refference ,
Thanks for your reply.I had a workshop in China and make so many types of tube amplifiers just like 300B,845,el34,6c33 etc. i like 300B SE very much,which also use another 300B works as power supply,haha. |
#5 |
a Candy for everyone......
#6 |
Hi Luck ,
Nice work , congratulations again . I do like this one more than the first one . Carlos |
#7 |
There are more information of tube hybrid amplifier for your reference.
http://www.head-fi.org/forums/f21/au...anyone-419935/
I like tube amplifiers and music. |
#8 |
Hi Luck, greetings from Japan!
I bought two PCB's in ShenZhen, China. The PCB's are as follows: 1: 6N3-T tube based line amplifier 2: Tripath TA2024 based Class-D Power Amplifier These two PCB's are shown in my Blog below(sorry in Japanese). http://ja1cty.at.webry.info/200903/article_7.html I am planning to build HYBRID AMPLIFIER to utilize above two PCB's. I hope the amplifier outputs cool sound at low frequency by Class-D and brilliant sonic at middle frequency by 6N3-T. |
#9 |
Nice work guys.
This is my latest project. This a hybrid class D amp. I used 2 x Hypex UCD180, bypassed the input opamp buffer with JJ E88CC gold ( balanced and matched) SRPP stage and used a Classic housing( not a small one) and Rcore transformer. 4 inputs and Alps potmeter. And it sounds relaxed you can listen the hole day to it. Ronny |
#10 |
Hi,all,it seems the PCB above is a 6N3(5670) SRPPdesigned.
My design is a ECC88 srpp output stage.And i use LM3886 as the power output. |
| FS: Small plastic project enclosure / cases | kec | Swap Meet | 8 | 2nd April 2008 09:55 PM |
| Amplifier cases in Oz | deandob | Parts | 4 | 6th August 2005 09:22 PM |
| Page generated in 0.10428 seconds (76.83% PHP - 23.17% MySQL) with 11 queries |
