diyAudio Sponsor
Old 26th January 2009, 09:50 PM   #1
Default Epiphone Galaxy 25 transformer problem
Hi all, I am a bit of a novice but here is my issue. Epiphone made two versions of the Galaxy Amp. One was made in China, and the other in Korea. I have a Korean model and the transformer blew. I had a local tech replace it with something else and after a couple of gigs the fuses started blowing. I am worried that the transformer is not working.
Does anyone know what I would need to look for or what the original transformers were? Can you not simply use a common transformer and then a series of resistors to step down the rectified voltage?
epiphone pacemaker 50 t uliami Tubes / Valves 1 14th July 2008 03:56 AM
Epiphone Galaxie 25 schematic TRguy Instruments and Amps 1 8th January 2008 04:41 PM
Epiphone LP standard tuner rattle SM2GXN Instruments and Amps 9 20th June 2005 02:50 PM
Page generated in 0.04806 seconds (71.72% PHP - 28.28% MySQL) with 10 queries
