diyAudio Sponsor
Old 26th January 2009, 09:14 AM   #1
Brit01 is offline Brit01  United Kingdom
Default SV83 vs EL84
What are your opinions on these 2 tubes regarding their sonic performance versus price?
The SV83's are quite a bit cheaper than the EL84's and are said to be very linear.
I see the pin configs are a little different and the screen of the SV83 has a lower voltage rating.
Would the SV83 be a good cheap tube to start off with using them in a simple Class A UL?
Old 26th January 2009, 09:36 AM   #2
Brett's Avatar
The cost difference will be trivial compared to postage etc.
What works best in the intended application? Use that.
Old 26th January 2009, 09:52 AM   #3
The SV83's work out to be about 3 USD each including postage.
EL84's see to go for about 15 USD each. Big difference here.
Old 26th January 2009, 02:04 PM   #4
45 is offline 45  Italy
45's Avatar
The SV83 can get only 200V on the G2 with 1.5W max dissipation, not 300V/2W as the standard EL84.
In UL or triode connections I would not go for anode+G2 voltages more than 200V.
Maybe you could still get an output power close to the EL84's (working at 250-300V) using a lower load impedance but I cannot say anything on how it would sound.
Old 26th January 2009, 02:32 PM   #5
Ty_Bower's Avatar
There is evidence which suggests the SV83 is identical in construction to the 6p14p (which is equivalent to EL84). The suspicion is that the SV83's lower voltage ratings were put on paper to support one of its other rated characteristics (long life, or low distortion, or something like that). In other words, it is possible that an EL84 would perform identically to the SV83 when operated under the conditions specified on the SV83 datasheets. Conversely, the SV83 ought to perform as well as an EL84 and should be able to handle the higher voltages.
The jury is still out on this one, and I believe that no one will ever know the truth with any certainty. Maybe Wavebourn will chime in - he seems to know something about the issue.
There's an old thread about it here:
6P15P Tubes: Push Pull Possible?
Some day I'm going to pick up a quad of SV83, and stick them into my amplifier with 410 volts on the plate and ultralinear taps wired to the screens. If they survive, I know what I'm going to believe.
Old 26th January 2009, 03:10 PM   #6
45's Avatar
The SV83 is just a rebranded 6P15P.
A 6P15P can take up to 330V on G2 but 1.5W screen grid dissipation still holds.
If you want to stay within 1.5W G2 dissipation you must not use more than 200V.
In fact there are no curves for Vg2 higher than 200V, exactly for the above reason.
A common NOS 6P14P sells for approx. 4$ on ebay (directly from russian guys) why risk with the SV83?
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 31 Yesterday 08:38 PM
6N1P & SV83 mu stage driving 845? dr.strangelove3 Tubes / Valves 19 8th January 2007 08:11 PM
PPP EL84 Amp Peter Menting Tubes / Valves 8 24th August 2005 05:34 AM
El84 Pp Mr. Triatic Tubes / Valves 11 7th August 2005 04:23 PM
Need sv83 tubes mbcouple Swap Meet 2 9th August 2004 11:52 PM
Page generated in 0.09149 seconds (72.48% PHP - 27.52% MySQL) with 10 queries
