diyAudio Sponsor
Old 25th January 2009, 01:24 PM   #1
Default A help with an soviet transformer.
Found this today. Do you know what it represents ?
I measured all the solder spots, but no more than several ohms.
http://img18.picoodle.com/img/img18/...7m_438d7f7.jpg
http://img19.picoodle.com/img/img19/...8m_530d7dd.jpg
http://img02.picoodle.com/img/img02/...9m_da2d878.jpg
http://img02.picoodle.com/img/img02/...0m_b1ea57e.jpg
Old 25th January 2009, 07:15 PM   #2
This transformer ТПП-220-400 В ist for 400 Hz frequency. Pls. use Google for search.
Andreas
Old 25th January 2009, 07:18 PM   #3
Searched with google with no answers.
http://lampilich.narod.ru/trans/400TPPpar06.html
Found this from a friend.
Old 25th January 2009, 07:46 PM   #4
Pls. look at page 2 in your link.
Regards Andreas
Old 25th January 2009, 08:50 PM   #5
Ty_Bower's Avatar
They used 400 Hz power on their ships and submarines. It makes for very small (equals lightweight) power transformers at a given VA rating. Unfortunately, you can't run these things on 60 Hz AC unless you de-rate the thing a lot. For all practical purposes, that transformer is useless.
Old 26th January 2009, 04:34 AM   #6
I can use the secondary side as primary like a step up transformer with the aid of a push pull oscillator.
I just need some auto batteries.
Old 26th January 2009, 06:13 AM   #7
sivan_and's Avatar
Send a message via Yahoo to sivan_and
they can be used in 400Hz SMPS !!!
SivanandBalan
Old 26th January 2009, 08:18 AM   #8
Tweeker is offline Tweeker  United States
If you have 3 they might be used to step up a car alternator.
Be sure your foil hat has a good low impedance ground.
Using mains transformer as output transformer Elias Tubes / Valves 175 3rd November 2009 08:36 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 05:05 PM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 10:43 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.09857 seconds (72.33% PHP - 27.67% MySQL) with 10 queries
