| diyAudio Sponsor | ||
Hi guys,
I'm going to have a shot at a very simple cathode follower pre-amp but using both sides of double triode like the 6N6P for the left and right channels. I have attached a photo (don't have any software to design these yet; if anyone knows of a good freeware please advise). How does this look? |
#2 | |
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 | |
![]() Quickly brushing my error aside what I was trying to achieve was using a single double triode for a stereo pre-amp. I've read that there shouldn't be any crosstalk between the channels. This was basically a design taken from a DecaWare driver stage. |
#4 |
What is the purpose of C1? If it's meant to be a cathode bypass, that's not the way to do it.
#5 |
The circuit has other problems besides C1. The output caps are too small if you ever want to drive a power amp with 100K or lower input impedance for example. I think you should either look for a published preamp project or work through a book like Morgan Jones on learning to design one.
#6 | ||
I've got my Aikido up and running on the breadboard right now. Very nice Quote:
#7 |
dont worry about it, most of us have done far worse.
As others have suggested, read morgan jones "valve amplifiers". this is a section on cathode followers that will answer all your questions. its a lot of learning in one book. |
#8 |
thks guys.
In the meantime JB's journals are great. Got some other pdf files from some other members. What I was trying to achieve was using both sides of the triode, for both channels. This is one channel of a very simple design that I'd like to modify using the same triode for both channels. How would I apply this concept to this design? |
#10 | |
Planning to use it as a versatile linestage, either with SS amps or tube amps. Maybe too much gain for a SS amp but the 6N6P is one of the tubes with a low gain, 16-24. |
| Can single PCM56P act as stereo? | terranigma | Digital Source | 1 | 27th February 2007 09:29 PM |
| Single or stereo speaker evaluation | Salas | Multi-Way | 23 | 16th August 2006 09:13 PM |
| Stereo Single 4780 | traw | Chip Amps | 3 | 16th February 2006 11:39 AM |
| From two amps stereo to single amp balanced? | Cradle22 | Solid State | 4 | 17th April 2003 05:16 PM |
| Page generated in 0.12094 seconds (74.19% PHP - 25.81% MySQL) with 11 queries |
