| diyAudio Sponsor | ||
I am working on a 13E1 project.
The datasheet does not give: µ for tetrode connection ra for tetrode connection gm for tetrode connection As I would like to test 13E1 connected as recommended by O H Shade et al, It would be great if anyone has the "missing data" |
#2 |
Addition of the screen deliberately breaks the intrinsic negative
feedback of the simple Triode. Therefore, there is no meaningful "Mu" for a Tetrode when strapped as such. You could calculate from Gm and Rp at any given point. But it isn't something that gives the same result at all points as it does with a Triode. For a Schaded Tetrode, Mu is computed externally. A weighted sample of the plate swing is fed back to the grid. The ratio of resistors and/or transfomers involved set the limit for Mu. Actual Schaded Mu is always somewhat less than the ratio of external feedback, as the gain of the tetrode itself is finite. It is a "connect the dots" game between a Tetrode's imperfect curves and the voltage fed back that gives the set of curves which once again resemble a Triode. The broken Triode is repaired! And we gain a screen to help boost the electrons along. Best of both worlds. |
#3 |
A norwegian enthusiast I spoke with told me that mu is about 220 and rp ca 10k6 tetrode connected .according to shade it should result in a mu ca 9.5 if 10 % feedback . Still missing gm tetrode
| testing a 13E1 | ErikdeBest | Tubes / Valves | 35 | 12th May 2009 03:13 PM |
| 13e1 | ErikdeBest | Swap Meet | 1 | 15th November 2008 05:52 PM |
| 13E1 SE design | Rob11966 | Tubes / Valves | 18 | 27th October 2008 02:09 PM |
| Anyone know this 13E1 design... | nickds1 | Tubes / Valves | 3 | 25th May 2007 09:25 AM |
| Page generated in 0.06700 seconds (68.06% PHP - 31.94% MySQL) with 10 queries |
