| diyAudio Sponsor | ||
I found the Beta-Follower in Morgan Jones book interesting, but need more gain. Im not sure how to proceed with biasing the pnp bjt for different op conditions. Say, 6SL7s, 600V B+, 2 1.2V IR led on base triode cathode ~2.8ma.
How to pick R1 and R2?
Be sure your foil hat has a good low impedance ground. |
#2 |
BC558 beta varies from 110 minimum to 800 max @ 2mA 5VCE.
I don't see how this oversimplified current load (in the middle of a totem, is "load" more descriptive than "source" or "sink"?) can be precisely computed in advance. Gonna need tweaking. The total voltage drop of the active current load should be the same as the two IR LEDs after all is said and done. Correct??? I'm thinking R1 should be approximately R2*Beta? That should bias the base to emitter junction right about dead center of the totem. But we don't know R2 just yet. For R2 then: Whatever voltage the two IR LEDs drop. Subtract the base to emitter drop of Q1. Divide the leftover load voltage in half. Half to drop across the collector, half to drop across R2. Ohms law figures R2 from there. Don't know if this is "optimal", but it ought to be in the ballpark. As I said, you are gonna need to tweak depending on Beta(HFE). R1 with the cap probably ought to be the pot... Might make less noise than R2 as the adjustible. Adding a resistor across C1 makes biasing much less dependant upon the exact known value of an unknown Beta. And you may then be able to dispense with a trimpot. |
#3 |
Kinda figured a pot would be needed, but wanted to be in the neighborhood. Feared HK or other issues if way off.
The example in Valve Amplifiers used 300V B+, 6J5, 8ma, 2 1.7V red LEDs. Q1 BC558. R1 was 100K, R2 100.
#4 |
If the current in the lower half of the totem is actively held
constant, does the lower cathode bias really require LEDs? Would an unbypassed resistor do just as well? |
#5 |
You wont lose gain, but you lose some PSRR.
#6 |
The more severe PSRR prob is with the Triode cathode follower
up top. The lower Triode is exposed to almost constant current, but the upper is fully vulnerable to B+ noise. I think I'd ditch the whole upper half and replace with NPN or N-Channel. Configured either as Mu Follower or Anti-Triode. Once you free your mind to throw sand at solving the top half, whats the big diff? Except that the overall PSRR is much better. And you don't have to float a heater. |
#7 |
If bypassing C1 with R5, then how two proceed?
#8 |
If I was gonna bypass C1 with a resistor and lower R1 to keep
the base cenetred in the totem, it might just mitigate the issue of an unknown beta. But also makes for a big leak that circumvents the active part of this load. The problem that dynamic impedance here can be no higher than R1. Because you always got AC short across C1. Maybe lowering R1 to lessen dependence on Beta isn't helping. Hmmm, how to fix? I don't care for this active load, just scrap it. The current and voltage here are small. Have you considered the flat plateau of a JFET? Either in self bias, or with a trimpot. Perhaps Toshiba 2SK373? |
| wanted: Coral Beta 8 or Beta 10 full range speaker | francofil | Swap Meet | 2 | 28th April 2010 08:34 AM |
| low-biasing or high biasing in Class-AB amps | Workhorse | Solid State | 124 | 18th October 2005 04:45 AM |
| beta followers | baggystevo82 | Tubes / Valves | 16 | 23rd June 2004 12:05 AM |
| Zen-V with followers | nobody special | Pass Labs | 23 | 20th July 2003 07:24 PM |
| Page generated in 0.11184 seconds (63.72% PHP - 36.28% MySQL) with 11 queries |
