| diyAudio Sponsor | ||
#11 | ||
My 300Beast push pull amp is biased at 70 mA per tube, a current that allows continuous current flow through both tubes over most of its normal operating range. The OPT is 6.6K ohms. This amp will make 18 to 20 watts by the strict class A definition determined by a scope probe across a 10 ohm resistor in the filament return. The amp will make about 26 watts in class AB before clipping starts. Now do I have a 18 watt class A amp with 8 watts of headroom, or do I have a 26 watt class AB amp, or do I have a 26 watt amp that remains in class A up to 18 watts. All of those statements are technically correct, and I really don't care what it is called. I tend to use the power at 5% distortion criteria for all of my amps, just so they are all measured the same. That makes it a classless 28 watt amp. I have seen plenty of BS advertising copy claiming rediculous Class A power levels especially in guitar amps, helping to fuel this mess. Quote:
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#12 |
TL, AA used to be a very informative place. It has become in stages, starting with Outside, then Water Cooler, and percolating down (or up) through the actual audio fora, a place of very low signal and very high noise amplitude. I am sorry to see this, just because I value every avenue of discourse, but there it is. I scan those lists, but the threads of interest have become so rare that I'm starting to consider it more of a duty than an opportunity.
It's just the same ol' tired webgeek stuff. Aloha, Poinz |
#13 | |
The Class B loadline is used here to determine both the power out and the h3 estimated distortion. It's the "Class B" loadline since it would be the actual loadline if the Q-Point current were set to Ip= 0. The justification for using it is that the primary of the OPT responds to differential current. If the same current is pulled by both finals at no-signal, there is no differential current (and no DC core magnetizing either) since the currents are equal. For this design, the blue loadline represents Rl= 1100R / phase. The Class A loadline is drawn with an Rl= 2200R since both VTs will be conducting the primary current, and so appear in series. The point where the Class B and Class A lines cross is the transition point from Class A to AB. The design nominal Q-Point puts the finals deep into Class AB, though it conforms to the Pd= ~0.8Pd(max) convention. Being that the 6BQ6GTB is a TV horizontal deflection type, in actual practice it was possible to push the Q-Point current up quite a bit: to ~53mA / plate. That's ~18.5W of Pd. Though rated for Pd= 12W, that's for the more demanding horizontal deflection duty. The finals don't red plate at the higher Pd, and the sonics are improved by going more towards Class A operation. So loadlines tell all. It does operate in Class A for low signal levels. |
#14 |
diyAudio Moderator Emeritus
Thanks for the opinons - just what I was hoping for. I tend to believe that to call an amp Class A, it has to operate in that region at all power levels to clipping.
That of itself does not preclude the operation of an AB amp in Class A at low levels. Just whether the quality of the sound at that low level would be as good as if the amp had been designed for Class A at all levels is another issue. I would expect the Class A amp to sound (and measure) a bit better in most such comparisons. An aspect to all this that especially interests me concerns class of operation and tube type, in PP. There have been many and varied writings on this, but the most common view appears to be that triodes are at their best in Class A, while pentodes and beam tetrodes perform better in AB, both in native 'pentode' mode and in ultralinear. This is, of course, a generalization but it seems to be the gist of what I've read. I can't speak from experience on this, because I have neither the means nor the time to carry out any meaningful experiments of my own, but I daresay others may have done so. |
#15 |
If maximum plate efficiency exceeds 50%, I tend to view it as not class A, whatever the power level.
Be sure your foil hat has a good low impedance ground. |
#16 | ||
I read an interesting (which has been kept quiet) study that showed that as we went from analog to digital cell phones, then lowered the bit rate on the digital phones to accomodate more users, the amount of subconsious processing power required by the human brain to understand the conversation has increased. This has led to more distracted users which can be dangerous if the user is doing something important while using the phone, say driving. Some digital formats are much worse than others in that regard. Quote:
A typical P-P class AB design places a lower load impedance on the tubes to extract more power. This would tend to compromize the "class A" operation at lower levels since the output tubes are working harder leading to higher distortion. Then if a ton of GNFB was heaped on to reduce the distortion..... When the amp is operating "class A" both output tubes are conducting. The output impedance of the amp (damping factor seen by the speaker) is determined by the two tubes and the OPT. When the amp goes into Class AB only one tube is conducting on signal peaks. Therefore the output impedance can nearly double as the signal reaches a peak. Some golden eared people claim to be able to hear the transition from A to AB, but I believe this is just AA speak. What I have seen is the transition from A to AB is gradual. The Rp of the tube being driven to cutoff increases as the tube approaches cutoff. The Rp of the driven tube is reduced as it is driven farther towards saturation. This effect is more pronounced with triodes. This can cause distortion on strong signals when combined with low load impedances. Again the usual cure is NFB. My 300 Beast was originally concieved as a class A design with zero feedback, planned for operation near 100 mA per tube with 360 volts on the plates and a 6.6K OPT. During the development I found that it sounded better to me with more voltage (400 volts) and less current (70 - 75 mA). In normal operation the amp probably averages 2 or 3 watts with peaks reaching 20+ watts. That is pretty dang loud and ear + speaker compression will be dominant over the "transition from A to AB".
#17 |
Gingertube and Miles are right. But, I find it much easier to refer to the ClassA current limit. eg. a 20W into 8r0 ClassAB push pull amplifier with 100mA of bias current (SS or it's transformed equivalent for a valve/tube amp) will stay in ClassA for all output currents upto 200mApk. Above 200mA one half of the output devices no longer control the output current. That 20W amp is capable of 17.9Vpk into 8r0 and 2.2Apk into 8r0. The ClassA limit is 200mApk. A little bit of Ohm's law shows that this 20W amp remains in ClassA for all (unclipped) outputs when driving loads greater than or equal to 90r0, not just at low signal levels.
regards Andrew T. |
#18 | |
#19 | ||
#20 | |
| Class Evolution-Modulating SMPS output to track audio signal | vectorplane | Power Supplies | 42 | 13th January 2007 01:33 PM |
| Audio Signal Amplitude Levels..? | xitronics | Analog Line Level | 0 | 16th October 2006 05:19 PM |
| Class-D modules no-signal power | Pierre | Class D | 1 | 28th June 2006 12:38 PM |
| Balanced Signal Levels- voltages?? | lgreen | Parts | 5 | 6th April 2004 04:22 PM |
| Page generated in 0.16654 seconds (86.20% PHP - 13.80% MySQL) with 10 queries |
