is it ok to route the wires, that they are touching the chassis? Or is it better to route wire about 1 cm above chassis? Is there significant (audible) capacitive coupling between the wire touching the chassis? |
#2 |
My wires which are touching (routed along) the chassis are just B+ and ground return wires. Will my amp sound better, if those wires will not be touching the chassis?
#3 | ||
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#4 |
diyAudio Moderator Emeritus
I agree with Hollowstate. The only time I think it might matter is if there are ground currents running around the chassis because of multiple earthing points. That might caused induce hum in nearby wiring.
#5 |
Thank you guys very much!
| Layout and wiring advice | Nohabla | Chip Amps | 4 | 28th January 2009 12:46 PM |
| ZV5 PS layout question | seventenths | Pass Labs | 3 | 24th May 2008 08:08 PM |
| UCD700 Layout and Wiring | GregD | Class D | 8 | 17th October 2006 03:05 PM |
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| Aleph-2 PSU wiring layout question | moe29 | Pass Labs | 5 | 21st August 2003 09:42 PM |
