diyAudio Sponsor
Old 21st January 2009, 10:43 PM   #1
Default series or parallel?
i hate to keep bothering everyone over this amp problem of mine but i have posted a link with the schematics and was wandering if someone could tell me whether the filaments were in series or not. thanks, wendell.
http://techpreservation.dyndns.org/b...Schematics.pdf
Old 22nd January 2009, 03:26 AM   #2
The filaments are in parallel.
Hey is for horses.
Old 22nd January 2009, 05:19 AM   #3
Strange , but I only see a 6.3V source for heater filaments on this schematic. What are they using to power the 12AT7's heater filaments ?
.............................Blake
Keep it simple
My Page Of SV and DIY Stereo Links
Old 22nd January 2009, 05:31 AM   #4
12AX7,12AU7,12AT7 (and many other) filaments can be powered two ways - pin 9 is the centertap of pins 4 and 5.
So ... 12.6 volts to pins 4 and 5, or, 6.3 volts - one side to pins 4 and 5 shorted, the other side to pin 9.
As a 12.6 volt filament, the tube will draw 300 ma - as a 6.3, 600 ma.
Look at the datasheet for the tube on http://www.duncanamps.com - it will be apparent.
If not, many are here with much more knowledge than me.
Hey is for horses.
Old 22nd January 2009, 10:31 AM   #5
Default amp dead
so would it be safe to assume that the transformer would be the culprit?
Old 22nd January 2009, 04:42 PM   #6
Thanks Charley ! I was unaware of the optional 6-12V heater arrangement !
Medicman ,
amp is dead!
Keep it simple
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 24 10th May 2009 03:24 AM
Series vs parallel? legendaryfrog Full Range 5 14th December 2006 02:50 PM
series vs parallel SPL? 2litre Multi-Way 16 22nd February 2006 09:58 AM
What would you do? series/parallel MtnBob Multi-Way 13 14th April 2005 10:17 PM
Page generated in 0.07580 seconds (73.58% PHP - 26.42% MySQL) with 10 queries
