Old 13th April 2003, 07:27 AM   #1
Jay is offline Jay  Indonesia
Question Where’s ECC81 data?
I’m building a preamp using CV4024/ECC81 or 12AX7 or 7819 (in triode mode) or other tubes I have on hand. Firstly I will use CV4024 on the first stage and any combination of 2 tubes in the later stage acting in mu-follower.
Sadly, I couldn’t find the data for ECC81 (the Plate Voltage VS. Current). Anyone can help?
Thanks…
Old 13th April 2003, 07:47 AM   #2
corbato is offline corbato  India
corbato's Avatar
Default ecc81
datasheet
Old 13th April 2003, 09:37 AM   #3
Brett's Avatar
Tube data can be found here
http://frank.nostalgiaair.org/
Old 13th April 2003, 11:24 AM   #4
Thank you... I got them
7 pin ECC81. Cassiel Tubes / Valves 9 16th February 2009 02:00 PM
ECC81 Tobruk Tubes / Valves 6 25th April 2007 02:47 PM
ecc81 gianis Swap Meet 0 12th June 2006 08:44 PM
Brimar ECC81 tuathal Tubes / Valves 5 8th June 2004 08:41 PM
ECC81 or 83 or 85 or 88 ??? Bernhard Tubes / Valves 1 26th December 2003 03:57 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
