diyAudio Sponsor
Old 21st January 2009, 03:14 PM   #1
kk84 is offline kk84  Poland
Default GK71 B+ turn on delay
Hi folks.
Building power supply I`ve reached one difficulty. How to solve turn on delay circuit - switching element. Biggest problem is unavaliability of high voltage relays, most of scr`s or triacs reaches 600-800V and thats it. In short time ill try to put some schematics so We can think about solution. Maybe series connection of two scr`s or triacs ? ..
Old 21st January 2009, 03:20 PM   #2
Well,
what kind of voltage level do we talk here?
brgds
Michael
Old 21st January 2009, 05:21 PM   #3
richwalters's Avatar
Short of ideas ? try this. Obviously modify for higher voltages and reset. loads of possibilities. Don't use coolMos. They have poorly designed gates and will oscillate.
richy
Old 22nd January 2009, 07:02 AM   #4
looks ok, there are lots of possibilities, but kk84 seems in the need of something that is capable of switching much higher voltages, as the normal FET, Triac or Thyristor ratings seem to low for him?
My take a very high Voltages: use a Filament-transformer and a High-Voltage Transformer and do a staggered turn on, so you only need to switch the primary side...
Michael
Old 2nd February 2009, 07:31 PM   #5
Hey.
Thanks for reply, sorry for My absence . Of course issue was high voltage switching element in B+ power supply, switchung voltage of 1100V. Already found an thyrystor capable of handling such high voltage , here`s datasheet :
http://pdf1.alldatasheet.com/datashe...S/TYN1225.html
SCR driven in classic aplication with Ug = 12V, Rg = 33R. In short time i`ll post schematics of working power supply.
Have a nice evening all.
556 timer for led turn on with delay larryg Parts 0 21st October 2007 06:47 PM
Delay turn on circuit for amps square_wave Solid State 37 12th September 2007 10:28 AM
Simple turn-on delay elizard Solid State 1 31st March 2004 05:45 PM
Page generated in 0.07815 seconds (71.95% PHP - 28.05% MySQL) with 11 queries
