diyAudio Sponsor
Old 21st January 2009, 01:20 PM   #1
Default Paralleling Triodes in a 6SN7GT
Hello,
I am sure this is a newbie question but I am just getting my feet we in tube circuit building.
I am building a preamp circuit using a 6sn7gt. I have it configured as an anode follower, with an Ra = 20Kohm and Rk = 500ohms. I have a 250Kohm grid resistor.
My question is, if I tie both triodes together inside the tube (pin1 to 4, 2 to 5, 3 to 6) does this throw the calculations off for Ra and Rk? Should I double their values to have it work correctly? Thanks for any help.
Old 21st January 2009, 03:51 PM   #2
dsavitsk's Avatar
rp is halved, Gm doubles, current doubles. If you look at the plate curves, double the current numbers on the LHS to make your calculations.
The grid leak stays the same, the load (for the same line) can be halved, and the cathode resistor, for the same bias, can be cut in half.
http://www.ecpaudio.com
Old 21st January 2009, 04:58 PM   #3
thanks - I was not sure about the load resistance either. It seemed like a shame to let the other triode in the tube just sit there unused!
6SN7 or 6SN7GT?? Brit01 Tubes / Valves 6 27th July 2008 12:13 AM
6SN7GT brand chipvn Tubes / Valves 0 20th May 2008 03:38 AM
6SN7GT SRSE Linestage Geek Tubes / Valves 6 24th August 2007 04:31 AM
Help! 6sn7GT Matthewong Tubes / Valves 31 29th June 2005 02:38 PM
6sn7GT sunseeker Tubes / Valves 11 17th March 2005 04:56 PM
Page generated in 0.06592 seconds (69.72% PHP - 30.28% MySQL) with 10 queries
