#121 |
Well tubesteve , since when do real tube lovers just look at plate curves and distortion characteristics on paper in order to choose a tube?
I am sure your discovery will enlighten Lamm, Borbely, B.A.T. etc so that they chuck out all those trashy 6c33's.
``The author always assumes that when power is applied , the amplifier will explode or ,at the very least, catch fire.´´ Morgan Jones, Building Valve Amplifiers. Last edited by protos; 6th November 2009 at 06:55 PM. |
#122 | |
No,no,no,no,nooo, I like this tube why should I listen to you I dont care what tube or car or what ever you like. If you find another tube more accurate it is up to you but do not point your finger at me and find that I am doing is wrong.
I can tell you that I have good listening experience to both DIY and factory-built amplifier tubes with 300B, 2A3, KT88, EL34, GM70, 6550, SE, SET, PP, SEPP, PPP, OTL you name it. But one day I came home to an friend who has two BAT VK150 I almost fell off the sofa where I sat it was the first time I heard a tube amp that I did not sounds sickly-sweet. I own a couple of others tube amps but my 6C33C SET gives me more joy right now. Anders Quote:
#123 |
this is personal, others may not like the sound. at the end, we are talking about spices an herbes in a menue. i think, as long as everyone is happy with any tube and sound he/she likes, there will be no war. tubes are pieceful animals, connecting people, thats the good news.
as an engineer i see things a bit different, bcc. we have to try, to satisfy a maximum amount of possible buyers. i think, you understand that position. but: we all love our tubes! |
#124 | |
I,m new here and I will build my first SE amp .In the past I have build few PP desings,but now I will try SE with 6c33 .I have look design vom Ari and is simple but have no fedback how it works -sounds in praxis.What mod do have you done on PS ? I have idea to regulate driver and power tube voltage and also heat driver with DC ?What OT are you using . I have one with 600 ohm 400 ma and 4-8 ohm output .R on primar winding is 42 ohm.For me sound is on first place ,power is not so important .Have also se Borbrly design but i dont know how performed ? Thanks for answer gsb
yeti |
#125 | |
Since spring t.Y. I'm trying to do something upon jogi's roehrenbude, but "a long hot summer" made my plans totally impossible. At the time I have almost all components, but none output transformer. Any news by your project? Cheers! BTW Yeti? Any relation to Miran Vodovnik?
#126 |
Hi !
I have most parts on the bench ( NOS 6BL7 from GE 1963 ,also 6LS7 and 6c33 from 1980 matched ) I,m not shure what plan i use ,but tend also to try one from Jogis Rohrenbude ,i think one from Ernst Roessler but another schematic with 6LS7 in the front and 6BL7 as driver.OT will be one from Gerd Reinhofer .I think i will use a mix of ptp wiring and pcb for input valves .I have not yet worked with 6c33 but drift of working point is one of problems .I,m here in Gemany in contact with programer -to implement an ic controler to regulate and monitoring bias, voltage and warm up phase will be with controler also simpler.But it is not finished yet.I must also buy PT -toroid custom wound (Tovornik -Slovenia ) No i dont know Mr.Vodovnik ,I,m form MB. Yeti
yeti |
#127 |
Seems that the low primary impedance of the OPT sort of negates the low output impedance "potential" of the 633C-B, what is the max primary impedance recommended?
#128 |
to be serious: i cann't really understand the enthusiasm about that voltage regulator tube, ist not so linear, it likes drifting like nearly all of these beasts, it needs driving power, it has a big heater power consumption and there are some other issues as well. the only advantage it seems to have: it looks big, impressive, and provides a big glow. at the end, its not a real good triode as there are other, better ones. i know, there are lovers for that bomb, for what reason ever.we all know: "i have designed it, so it must be impedance, and if the core is not big enough, there is lack of bass.
#129 | |
not only by that tube, very often is hard to understand people's enthusiasm... ![]() But... that make our life non-boring ![]() BTW, do you have any essentially better suggestion? Cheers, |
#130 |
Hi Yeti,
any news by your 6c33c project? About OT... Do you know that: Leszek Ogonowski transformatory sieciowe g?o?nikowe single ended SE push-pull PP audio d?awiki wzmacniacze lampowe akcesoria What a shame! ![]() Mr. Miran Vodovnik is Slovenian shot-putter (also record holder). BTW, I'm from MB too... Cheers, |
| 6c33c PSE | mark_titano | Tubes / Valves | 13 | 20th December 2010 04:49 AM |
| 6C33C-EB / 6C33C-EV extended life ? | ger56 | Tubes / Valves | 2 | 14th October 2007 05:54 PM |
| WTB 6c33c-b | woody | Swap Meet | 0 | 20th September 2005 07:36 PM |
| WTB 6c33c-b | woody | Swap Meet | 0 | 8th September 2005 02:41 PM |
| 6c33c-b Se | morfeas | Tubes / Valves | 3 | 19th November 2004 11:55 AM |
