| diyAudio Sponsor | ||
i need some help please. i have a acoustic g100t tube amp, i was playing it and all of a sudden it just quit. the power light on the fron is on but none of the tubes light up. i removed the chasis and eyeballed inside nothing looked or smelled burnt. what could it be? thanks, wendell.
#2 |
diyAudio Moderator Emeritus
Fuse?
Transformer primary winding blown? |
#3 |
Schematic?
Ears aren't microphones. |
#4 |
light is on, ergo there is power to the unit. Tubes are not glowing, ergo there is no heater supply. Thats it. Without a schematic and some voltage readings, there is no more to be said...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#5 |
Account Disabled
Sounds like a dead power trannie
#6 |
i believe that the heater supply is correct because there is primary voltage. i will post a schematic for it tommorow. thanks everyone.
#7 |
Primary voltage without lit tubes likely means something's sideways in the filament supply. Burnt windings are usually pretty pungent for weeks so luck might still be on your side.
#8 |
here is part of the schematic i found, the power indicator light comes on the front but there are absolutely no lit tubes. i'm really not very good at troubleshooting electronic circuits. i cant smell anything from the transformer here is the link that has the entire schematic i couldn't attach it because it's too big. thanks again for all your help.
http://techpreservation.dyndns.org/b...Schematics.pdf |
#9 |
I wonder if this a series filament setup?, in that case it could mearly be a bad tube. A volt meter would be a real help here. I noticed that Antique Electronic Supply has a real digital one (S-Z3220) for $50. This is somthing that will pay for itself many times over as so many problems can be diagnosed with simple voltage/resistance measurnents.
#10 |
Medicman,
Do you own a volt meter or multi meter ? If so, measure the voltage between the two green leads of the power supply transformer. These are the heater filament leads and should measure 6 volts or so. If you don't have a meter , you NEED one. Look here for a decent meter on the cheap : http://www.parts-express.com/wizards...n&WebPage_ID=3 Have you checked ALL the fuses ? .............................Blake |
| Dead AKG P 8E with X 8S R | Bernhard | Analogue Source | 10 | 2nd April 2008 10:55 AM |
| dead amp | ddoyle | Chip Amps | 20 | 30th July 2007 01:30 AM |
| Dead Amp?? | Shim | Solid State | 12 | 5th June 2007 04:00 PM |
| Nak mb-70 dead ? | MadMutt | Car Audio | 10 | 5th April 2007 03:18 AM |
| is my amp dead? :( | torxim | Car Audio | 5 | 18th September 2004 10:37 AM |
| Page generated in 0.09051 seconds (81.39% PHP - 18.61% MySQL) with 10 queries |
