Quad KT88 oscillation problem
Old 20th January 2009, 03:06 AM   #1
chris.busch is offline chris.busch  United States
chris.busch's Avatar
Post Quad KT88 oscillation problem
Gentlemen,
Your help and experience would be greatly appreciated. I've just completed the first of 2 quad KT88 based amplifiers, and I'm unable to surpress a very persistant self-oscillation (with no input to the grids). The circuit utilizes 4 KT88s (Electro Harmonix) in a push-pull parallel, ultra linear configuration (biased for class AB1, but adjustable) with 6SN7s drivers, preamp and phase inverters. The output transformer is a Hammond 1650W (1.9K CT pri.). The power supplies are all choke-input. The B+ supply for the finals is 570 VDC with 2 LC sections (10H chokes and 220 UFD caps) in the filter. The supply is very"stiff" and will easily supply 600 ma with less than 15 V droop. Ripple is <.01% RMS with a full load. B+ for the drivers, preamp and phase inverters is 220 VDC with a single LC section (7H + 440 UFD) which will supply 100 ma with <.01% RMS ripple. The bias supply provides -90VDC again with a single LC filter (25H + 440 UFD) and is adjustable for each pair of tubes. The filaments are run on clean DC as well.
Here's the problem: with no drive (coupling caps from the drivers completely disconnected) and using just 2 tubes in the circuit, it is completely stable at any idling current (typically ~ 30ma / tube, but values from 0 to 100ma are completely solid). If you add the second pair of parallel tubes and increase the idle current to anything over ~20 ma/ tube, the circuit immediately goes into oscillation at approximately 60 Khz. All the tubes appear to be good (any 2 of the 4 will work fine and exhibit similar transfer characteristics). Lead dress is not a problem, the output is driving a solid 4 ohm, 400W, non-inductive load, all the supplies are well-bypassed, and the oscillation is not originating in the drivers. Does anyone have any ideas?
All help would be greatly appreciated,
Chris
Old 20th January 2009, 03:44 AM   #2
HollowState is offline HollowState  United States
HollowState's Avatar
Hi Chris,
The first thing I would do is to carefully verify the color coding on the output transformer primary windings by checking the DC resistance and their relationship to each other. If this pans out OK, you may need some stopper resistors for the KT88's. You may or may not need all of these typical values mounted right at the sockets. or 1 watt carbon comps or film.
1000 ohms for the control grids.
470 ohms for the screens.
10 or 20 ohms in the plates.
There cannot, and never will be, any progress in society, vis-a-vis racism, so long as the concept of celebrating Diversity -- in it's current, politically-correct, deliberate, punitively extractive form -- continues.
Old 20th January 2009, 04:19 AM   #3
audiopro is offline audiopro  Canada
Hi Chris,
You will probably need grid stoppers at pin 5. You may also need to put a resistor in series with the UL tap and each screen. 100 to 470R should do it. You might also try a 1k resistor in series with about a 100pf cap between the screen and the plate taps on the transformer - both phases.
Dan Santoni
www.dtsaudioelectronics.com
Old 20th January 2009, 11:57 PM   #4
Thank you so much for the assistance. I'll implement the changes that you suggested and let you know the results. I really appreciate the expertise.
Chris
Old 21st January 2009, 03:15 AM   #5
On Hiatus
SY's Avatar
Stoppers could help, but you might want to go through your circuit and do a stability analysis. It's possible that the additional capacitance of the second pair of output tubes puts a pole right where you don't need it.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 21st January 2009, 03:29 AM   #6
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
Anothr vote for stoppers, esp. with beam tetrodes - very prone to oscillate.
Old 21st January 2009, 03:35 AM   #7
kevinkr's Avatar
You might find the screen grids are the culprit here, and I recommend around 100 ohms directly at each screen grid. (pin4)
The only other concern would be if there was enough phase shift in the primary at 60kHz to allow the amplifier to oscillate.
I have had similar problems in the past and I usually found that there was a vhf oscillation at the root of it all, and it was due to feedback at the screens, if this is the case the resistors should take care of it.
Stoppers on the grids are highly recommended and something in the range of 1K - 10K is typical. I tend to favor values around 1K. Again must be installed right at pin 5 as previously mentioned.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 21st January 2009, 05:21 AM   #8
richwalters is offline richwalters
richwalters's Avatar
Chris; that circuit is a very poor design, I suspect the previous stages are so slew-rate slugged that the audio response is poor to avoid the output stage oscillating. There are no grid stoppers in the screen grid circuits, and the design with KT88's (high gm tubes) will guarantee to oscillate at the leakage resonant freq of the o/p tranny. I've enclosed a sim design with tamed output stage with sim power. Note; 570V B+ and an wild oscillating primary is mighty dangerous stuff, and inadequately rated components will simply puff up. One is up against the leakage/reactive components of the o/p tranny, and snubbing sim to that in the pic enclosed sorted my problem out. The screen to screen is a drastic measure, this highlights the inherent leakage inductance between these taps when compared to primary as the transformer size increases.
I presume you are using 40% UL taps. In reality I used 5-7W series snubber resistors (not wire wound) and min 1kV rated polypropy caps. Considerable amount of power is dissipated in the snubbers so be careful doing 5-10Khz square wave tests at power.This is to be taken seriously.
KT88's are becoming expensive and every method should be used to protect them, a low wattage screen resistor will do alot. Note 630mA fuse used in CT in pic. You haven't given a layout ? This will also play a big part.
Attempting to tame a wild rat isn't easy. Good luck
richy
Old 21st January 2009, 06:24 AM   #9
A pic of some output stage waveform differences. Poorish bild quality but they illustrate before and after.
I wonder how many tube amps look like this ? The poor quality lower waveform goes into oscillation with a LS crossover .. The output stage with the upper snubbered square wave can take another 20dB global nfb before instability occurs. This won't be in every case and depends on tap and quality of o/p tranny.
richy
Old 24th January 2009, 07:02 PM   #10
Thank you all for the help.
Success (and very cautious optimism). Added the 1K stops at each of the control grids and the 470s at the screens as suggested. Not only is it now stable, but a cursery look at the output waveform (with a sine wave input) is surprisingly good with zero NF (other than the inherent NF from the untralinear configuration). I'm sure I'm in for lots more tuning once I look at the square wave response and the THD/IM numbers, but for now, it's stable enough to develop further which is great.
One last question: what have you found to be the optimum idle current for a KT88 in fixed bias, ultralinear P-P configuration running AB1 with 550-570V on the plates? The data sheets are all over the place from 30 ma. to 90 ma.
Chris
Quad KT88 oscillation problemHide this!Advertise here!
oscillation problem ABO Solid State 30 3rd March 2018 07:03 PM
Quad Golden Lion Genalex kt88 reissues Ang Swap Meet 1 3rd August 2009 10:11 PM
Se KT88 with Quad ESL Drewaudio Tubes / Valves 5 18th February 2007 01:40 AM
CDM-12 Problem - Whistling / Oscillation poynton Digital Source 4 8th December 2005 07:50 PM
