diyAudio Sponsor
Old 19th January 2009, 07:03 PM   #1
Default Installed 12" Speaker in Pro Jr---Now What??
A friend has asked me to make his '94 Pro Jr (Tweed version) gig worthy. I checked the tubes, replacing a microphonic 12ax7. I installed a Vox Neo-Dog (same as Celestion Century Vintage), and a larger OT to match this 16 ohm speaker. This is the only speaker which had a small enough magnet to fit, and I still had to trim the heatsink to manage it.
When I play it, it doesn't seem to have much headroom or snap. I don't have another EL84-based amp to compare it to, but compared to a Deluxe Reverb or my Rivera 30-112 (running on 6V6's as well) there is nowhere near the clean output.
The tubes are running stock fixed bias, which I think is about 14 watts per EL84----should this be adjusted?
The circuit looks like it has quite a bit of its gain dumped between stages, presumably to increase distortion (ala Soldano). Should this be revised?
The power tranny is also quite puny--is it just too much to ask of a Pro Jr?
Old 19th January 2009, 08:22 PM   #2
Trout is offline Trout  United States
Trout's Avatar
If you could shoehorn in a Blackface Deluxe PT & OT in there, then tweak the fixed bias circuit you could most likely get her pumping out about 22W with a pair of JJ 6V6's instead of the EL84's.
Pretty extensive mods though.
Might be easier to just upgrade to a bigger amp.
Old 19th January 2009, 10:23 PM   #3
Default Pro Jr Upgrades
I already installed the OT from a Mesa 50W amp, so it should be adequate iron. I think a DR power trans could be prohibitive unless you have a used one fairly cheap---I see you are in Geneva/Elburn, and I'm in Geneva! Email me if you have something lying around (I 'm too new to this forum to have outgoing emails).
Matthew
Speaker "Tune Up"? / Speaker alternatives Zap Multi-Way 0 31st May 2008 05:11 AM
DIY "speaker box" ("BOOM BOX"). Help needed. MASantos Full Range 6 2nd September 2007 12:00 PM
Just installed VAM1202..... martipie Digital Source 2 28th April 2006 11:01 PM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
Just installed EV in my OB's hurdy_gurdyman Multi-Way 2 1st June 2003 04:46 AM
Page generated in 0.07011 seconds (72.21% PHP - 27.79% MySQL) with 10 queries
