diyAudio Sponsor
Old 19th January 2009, 09:01 AM   #1
Stuey is offline Stuey  Australia
Default Socket for 6AQ5
Hi all,
I'm new to tubes/valves and am in the process of collecting all the bits to build a Moebius line stage using 6AQ5's.
I see a current thread where a guy had trouble with his octal sockets, so I thought I'd ask - how do I identify the correct sockets for the 6AQ5? I know them as seven pin miniature sockets, but I've variously seen them described as B7G, and on the GE datasheet, E7-1.
Can you help?
Cheers
Stuey
Old 19th January 2009, 10:42 AM   #2
hey-Hey!!!,
The 6AQ5 does take the small 7-pin socket. Same as 6AU6 for instance. The octal is *QUITE* different...
cheers,
Douglas
the Tnuctipun will return
Old 19th January 2009, 11:16 PM   #3
Geez Douglas, I'm not QUITE that thick!
Yes, I know the octal has eight pins. I was just referring to another thread where the poster got sockets that his valves wouldn't fit, and I don't want to end up in that situation. Given that much of my stuff comes from o/seas.
I know also that it's a small seven pin socket that I need...
Can I put it another way? Is there more than one type of 'small seven pin' socket configuration?
Cheers for the info.
Stuey
Old 19th January 2009, 11:29 PM   #4
anatech is offline anatech  Canada
anatech's Avatar
Hi Stuey,
It's just a simple 7-pin tube socket. You need to specify whether you want PCB mount or chassis mount. Some chassis sockets may come with supports or hold downs. I have even seen shielded 7-pin sockets. Some PCB sockets may have different circumference for the pins, but that should be about it.
Note too that sockets may be phenolic, mica filled molded, ceramic or molded. The ceramic ones can deal with heat better, but many tube radios used phenolic sockets.
On to contacts. Forget gold plated, that disappears quickly. Cadmium plated (I think) were standard and preferred. Someone may even come out with a nickel or brass type.
So there you have it. Larger sockets are made with various pin configurations. Some really old types are large like octal, but with 7 contacts. These are special and should be noted as such.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 19th January 2009, 11:34 PM   #5
Cheers Chris. I have some lined up that are silver plated, but my choice isn't because of this - they just look well made.
http://www.military-tubes.com/xtcomm...dd6d5b376c1fc1
There seems to be a fair bit of tinny looking junk out there!
Thanks.
Stu
Old 19th January 2009, 11:57 PM   #6
anatech's Avatar
Hey Stu,
Your link dumps me elsewhere. I did search and found part # 010241. It looks well made, and it's new. Go for it. The price is in line with what I would expect.
-Chris
Old 20th January 2009, 12:40 AM   #7
Stuey
My 813's take a 7-pin... is that it?
cheers,
Douglas
though that peg on top might be considered the eigth
Old 20th January 2009, 01:02 AM   #8
Yep, they're the ones Chris.
Stu
Old 20th January 2009, 01:34 AM   #9
Apex Jr is offline Apex Jr  United States
I have a large quantity of these in stock
http://www.apexjr.com/images/7PINPC1.jpg
These will work for the 6AQ5 and at .35 each
The 813 is the large 7 pin version and I should
also have those too...
Steve @ Apex Jr.
Old 20th January 2009, 01:52 AM   #10
anatech's Avatar
Hi Douglas,
You mean that your 813s are morbidly obese?
Anyway, I thought that all Tnuctipun were extinct after that one unified command. But then again, "food that talks" might fear that return for all time.
I don't know anything of the story, but I just had to investigate your tag line a little bit. Of course, this also revealed the meaning of your "handle". However, I had never thought of you as livestock. Cow, pig or sheep?
Hi Steve,
Geez, I should have been buying my sockets from you! The 7-pin you show there are pretty much garden variety and would work fine. I haven't looked further into your site, because I got a "page load error" [network timeout] trying to load http://www.apexjr.com/.
Ahhhh, now I'm in. Hey, I like those right angle 9-pin ceramic sockets you have. I have to say that your place is a wonderland for guys like me. It's a good thing you're located in CA and I didn't know about your place when I went to the first Burning Amp.
Some day I'm going to have to find out if there is an inexpensive way to ship to the Toronto, Ontario area. Will you accept Credit cards or PayPal at some point in the future?
-Chris
Help with 6AQ5 schematics kacernator Tubes / Valves 5 17th January 2008 11:46 AM
Driving 6AQ5's jerluwoo Tubes / Valves 10 22nd June 2007 05:08 PM
Please review my 6AQ5 Amp PRNDL Tubes / Valves 19 17th June 2007 06:34 PM
6aq5.......6v6....... diesel_tech Tubes / Valves 9 23rd February 2007 12:43 AM
Which 6AQ5 dstockwell Tubes / Valves 4 12th December 2005 11:05 AM
Page generated in 0.11350 seconds (83.47% PHP - 16.53% MySQL) with 10 queries
