diyAudio Sponsor
Old 18th January 2009, 08:06 PM   #1
Question Counterpoint SA-12 outputs 2SK134/2SJ49 work??
Hi gang,
Relatively new here, but been building hi end audio since the early 80's...
I have just dug out my old Counterpoint SA-12 after 10 years of storage and found a bag of MTM12N10's strapped to the side. Mmmm...seem to remember something about one channel failing??
Well, upon removal of the FET caps, I see that it has been repaired before with IRF130's and the /\/\ mentioned above. Well, knowing how fussy this amp is with using matched output devices, it's time to fix it properly. I have searched the web for the last 2 days and can't find any hard evidence of reasonable subs. I believe the original MOSFETs had PTC characteristics, and that seems to be hard to find in complementary pairs. Then I remembered I have 2 flats of 2SK134/2SJ49's sitting in my pile of valuable junk in the shop and thought I'd dig up the specs on those. Can't find temp curves but it looks from reports, that these had positive temp coef. as well. They are rated at 7A instead of 10 or 12, but they were still sucessfully used in pairs in 100WPC amps.
Your thoughts? Can I just drop these in, rebias to around 100-200mA and go?
Cheers
Paul
Old 19th January 2009, 01:25 PM   #2
Have a look here:-
http://www.datasheetarchive.com/
Old 26th August 2009, 11:06 PM   #3
SA-12 is offline SA-12  Canada
any update to this thread
Old 28th August 2009, 05:17 AM   #4
anatech is offline anatech  Canada
anatech's Avatar
Post Whoa there! Careful with mosfet outputs in these amps
Hi Paul,
The only sane way to rebuild this amplifier is to order a set from altavistaaudio, refrain from any of his upgrades.
I have hand matched a set of outputs for an SA-220 and also an SA-100 (same as yours almost) in the past. It took me two days of careful work and 50 of each mosfet to get a set I was happy with. In fact, it turned out to be a tighter set than any I've seen in these units. Since there is no source resistors used, the match is hyper-critical. Not really a good business plan if you ask me. Use the original numbers though! Right or wrong, they worked in this amp.
I used to do warranty service for Counterpoint in Canada. I am pretty familiar with them by now.
I am developing a modification to the output stage. I have already designed a couple other critical modifications to the basic circuit, the power supply and the DC offset balancing circuit (no, not active). The sound quality and stability has been vastly improved without losing the good part of the "Counterpoint sound". You can still identify it by sound only.
BTW, the original circuit requires that the 6922 tubes also be carefully matched. There is no getting around ridiculous amounts of by hand work if you plan to restore it. Some day when I'm happy with the output circuit change, I'll offer it as an upgrade. Right now there are two upgraded amplifier prototypes in use with a very happy Counterpoint owner. They are a few years old and still going fine, one is loaded with a very poorly matched set of outputs as a test. The new outputs are BJT types, and not a normal output stage either. Please proceed with great care here.
-Chris
"Just because you can, doesn't mean you should" © my Wife
FS: Lateral Mosfets 2SJ49/2SK134 housing Swap Meet 0 25th March 2009 11:49 AM
2SK134/2SJ49 for output of Counterpoint SA-12?? kilohertz Solid State 12 24th January 2009 02:44 AM
2sj49/2sk134 Brownlow Solid State 43 21st May 2008 03:17 AM
2sk134/2sj49 - 120watt amp fermatsEnigma Swap Meet 4 1st October 2006 09:58 PM
When the 6922 married the 2sj49/2sk134 ekaerin Solid State 4 11th June 2004 11:04 PM
Page generated in 0.08751 seconds (76.80% PHP - 23.20% MySQL) with 10 queries
